Clogged Windshield Washer nozzle
Old Apr 29, 2004 | 10:00 AM
Cossa's Avatar
Default Clogged Windshield Washer nozzle
It seems somehow I have a nozzle clogged... Any ideas on the easiest way to clear it?
Thanks!
Old Apr 29, 2004 | 10:10 AM
Dinnyin's Avatar
sewing needle
Old Apr 29, 2004 | 10:14 AM
Tegs2k's Avatar
Mine has done that a couple of times. This is what I've done.
Lift the hood.
Disconnect the hose from the clogged nozzle.
Slide the nozzle forward then pull up to remove it from the hood.
Use your air compressor to clear the nozzle.
This should fix the problem for you
Old Apr 29, 2004 | 12:15 PM
Hockey's Avatar
Why not just use your air compressor and skip all those other steps?
Old Apr 29, 2004 | 12:17 PM
LostWaffle's Avatar
It has hapened a few times on mine. I have a lazy fix that works about 50% of the time.
1) When the nozzle is clogged, you can try to dissolve through it from the back. Do 5-10 fast pulses of the winsshield water fluid. Nothing will come out, but it will start to dissolve the plug. Then wait.
2) Come back an hour later and it should be unplugged. You might have to pulse it a few times to make it work.
If that doesnt work....I wait for rain to cleanse my nozzle. Yeah, I'm that lazy.
Old Apr 29, 2004 | 01:52 PM
WhiteS2k's Avatar
[QUOTE]Originally posted by LostWaffle
Old Apr 30, 2004 | 05:01 AM
8BALL's Avatar
Originally posted by Dinnyin
sewing needle
Works every time!
Old Apr 30, 2004 | 06:26 AM
dayves2k's Avatar
[QUOTE]Originally posted by 8BALL
Jamie_Murray
Apr 23, 2011 06:16 AM
danx
Nov 10, 2008 04:38 PM
Jamie_Murray
Jan 11, 2008 12:16 PM
charles02
Aug 1, 2003 10:02 PM
Rx man
Mar 13, 2003 04:48 PM
