Leaky windshield nozzle?
Old Apr 13, 2008 | 05:15 PM
Jamie_Murray's Avatar
Default Leaky windshield nozzle?
Something odd that I've never seen on a car before.
Everytime I make a hard right hand turn, (or moderate for that matter) the windshield washer fluid streams out onto my hood.
This in turn creates spots on a freshly washed S! (not to mention depletes my washer reservoir.
Has anyone ever had this problem or heard of it?
Old Apr 13, 2008 | 07:21 PM
Vanishing Point's Avatar
Never!
Old Apr 13, 2008 | 08:24 PM
Moddiction's Avatar
Former Sponsor
Yeah mine leak some I think. I still runs from the nozzles all over my hood. Sucks. I'm going to look at them and inspect them to see if I can find anything. I think there is wax lodged in them from waxing my car, don't know why that would cause them to leak though. They do spray funny so will at least fix that hopefully. I'll post back if I can find anything that could help.
Old Apr 17, 2011 | 07:54 AM
sandiegan's Avatar
Anyone else ever find a resolution to this problem? This is happening to my car as well... leaking on the hood.
Old Apr 18, 2011 | 09:59 PM
SpitfireS's Avatar
Same here.
For about a 1/2 year now I've noticed it, it never happened before.
Now that I think about it... it started when I removed the hood to work on the engine.
Maybe the hose doesn't fit watertight on the fitting anymore.
Those hoses get warm under the hood - maybe they are dryed out?
Old Apr 20, 2011 | 12:17 PM
ahrmike's Avatar
Theres a one way check valve inside each sprayer. Its probably starting to get clogged up due to dust/dirt. Buy new nozzles and it'll be good to go.
Old Apr 20, 2011 | 07:05 PM
bronxbomber252's Avatar
I get the same issue at autox sometimes.
Old Apr 23, 2011 | 06:16 AM
SpitfireS's Avatar
The check valve is a seperate item (*) on my car.
As you can see, the spring is kaputt.
Its supposed to create some resistance, so the pump wil be able to get the water through but G-forces don't.
(*) - I found this part # 76829-SM1-004 but that's called a "I - joint" and according to the list there are 4 of them in the system.
Not on my car, just 2
So I guess the part # is not the check valve.
edit: 38571-SA5-621
That is a (Mitsuba) check valve.
$6,95 at CFL Honda
LATEOTT
Feb 13, 2009 08:28 AM
Jamie_Murray
Jan 11, 2008 12:16 PM
Cape Cod
Sep 2, 2003 07:22 PM
charles02
Aug 1, 2003 10:02 PM
Ruined 2
Jul 2, 2003 06:51 PM
