AC Removal
Old Oct 11, 2004 | 03:05 PM
jerrypeterson's Avatar
Default AC Removal
I was unable to turn up a specific length for the accessory belt with the AC compressor removed. Instead of feeding a tape measure around the plumbing, I was hoping one the gang had the numbers handy. A real bonus would be a common part number though.
After reviewing how the belt would be routed, I have a concern. The water pump pulley will go from 70% contact with the belt to around 40% after removing the AC compressor. Has this been identified as a problem or is there any way to mitigate this fact?
Old Oct 11, 2004 | 03:08 PM
krazik's Avatar
Administrator
45" 6 rib. 45.5 will work too, but the 45" is the ideal part.
any parts store can get it for you.
And no problem w/ the water pump.
Old Oct 11, 2004 | 03:12 PM
krazik's Avatar
Administrator
because you're a hosehead I googled it for you.
I use the Goodyear Gatorback Belt.
45" :: pt# 4060450
45.5" :: pt# 4060455
Old Oct 11, 2004 | 03:19 PM
Fabulous.
Old Oct 11, 2004 | 05:06 PM
jlucas's Avatar
Rylan, How long have you been using a 45"?
Old Oct 11, 2004 | 05:10 PM
krazik's Avatar
Administrator
I've actually be using a 45.5 for about 1.5 years. but according to the tensioner, I'm just outside the "ideal" range. Davepk has been running the 45" for just as long.
Old Oct 12, 2004 | 03:00 AM
jlucas's Avatar
Thanks for saving us some money.
tizbad2k
Mar 29, 2026 03:27 PM
rcasiano
Jan 11, 2016 09:10 AM
weiRtech
Jun 10, 2012 06:58 AM
DvS-
Feb 6, 2011 10:00 PM
krazik
Mar 15, 2003 05:16 PM
