E-Manage install
I finally found some time to install the e-manage.
What I initially did was to set the A.A.V values (Start Point to Point5) to display 0 on the Support tools Main Unit setting information by playing with the 5 "knobs" on the Emanage front panel. These were tempered by the previous owner.
I also set the last two knobs (hidden by the cover) to full counter clock wise (7 o'clock)
Jumpers were previously set to 4 - 8 - C
On ignition with engine still off , after around 4 sec the CEL turns on. if i turn off and on the CEL will come straight away. I reset the CEL by removing the battery terminals to try again and still again, after 4sec the CEL turns on.
I checked the parameters and the main unit settings and all seem fine.
I tried cranking the engine and on first impression it idles fine at around 2000rpm (still cold) and after 3/4 sec , the engine hesitates and switches off.
The strange thing is that the CEL comes on with engine still off
Anyone knows what the problem might be ?
Originally Posted by Stratocaster,Nov 1 2005, 05:11 AM
I would bet it is a 1259? Any takers?
I removed the E-mange out of the loop and the car is working fine and vtec is functioning normal.
I unticked all the MAP settings from the Parameter Settings, shouldn't this disable the MAP settings including VTEC ?
