E-Manage install
Old Oct 31, 2005 | 03:12 PM
Trip's Avatar
Default E-Manage install
I finally found some time to install the e-manage.
What I initially did was to set the A.A.V values (Start Point to Point5) to display 0 on the Support tools Main Unit setting information by playing with the 5 "knobs" on the Emanage front panel. These were tempered by the previous owner.
I also set the last two knobs (hidden by the cover) to full counter clock wise (7 o'clock)
Jumpers were previously set to 4 - 8 - C
On ignition with engine still off , after around 4 sec the CEL turns on. if i turn off and on the CEL will come straight away. I reset the CEL by removing the battery terminals to try again and still again, after 4sec the CEL turns on.
I checked the parameters and the main unit settings and all seem fine.
I tried cranking the engine and on first impression it idles fine at around 2000rpm (still cold) and after 3/4 sec , the engine hesitates and switches off.
The strange thing is that the CEL comes on with engine still off
Anyone knows what the problem might be ?
Old Oct 31, 2005 | 04:10 PM
Slows2k's Avatar
What code is stored?
Old Oct 31, 2005 | 04:12 PM
Trip's Avatar
CEL code. I do not have a reader
Old Oct 31, 2005 | 04:40 PM
Slows2k's Avatar
Having the CEL will help you figure out what the problem is.
Old Oct 31, 2005 | 06:11 PM
Stratocaster's Avatar
I would bet it is a 1259? Any takers?
Old Oct 31, 2005 | 10:13 PM
Trip's Avatar
Is that Vtec engagement failure ?
I removed the E-mange out of the loop and the car is working fine and vtec is functioning normal.
I unticked all the MAP settings from the Parameter Settings, shouldn't this disable the MAP settings including VTEC ?
Old Nov 1, 2005 | 05:35 AM
Yes it is a Vtec failure. But it is electical, atleast in my case it was. So recheck your wiring.
Old Nov 1, 2005 | 08:01 AM
Trip's Avatar
Very unlikly, I bought a ready made harness from Boomslang. I spliced in the following for datalogging
Knock C22
AITS C25
TPS C27
RPM A19
Power B1
Ground B2
Did not touch any VTEC cables
Old Nov 1, 2005 | 09:08 AM
Trip's Avatar
Just been looking at the wire harness. There is no Cable attached to C10 coming from the engine and the ECU is fed from the purple cable from the e-manage harness..
Is this right ?
Old Nov 1, 2005 | 12:48 PM
If C10 is connected on the ECU side (plug side) and not the header side (as seen below) It should be wired right. Check the WTS wires too.
