DIY Grounding Wires
Old Feb 25, 2006 | 08:21 AM
John_Z's Avatar
Default DIY Grounding Wires
I've always wanted to run a set of grounding wires but have heard both pros and cons. I figured I could make my own and if nothing happened, I'm only out a few bucks rather than $100 plus for ready made kits. I chose to ground 5 points: Head, Body, Block, Alt body, and Crossmember. I checked each spot with a multi-meter to make sure there was an active ground.
I used 8 gauge multistranded cable and crimped then heat shrinked the connectors. Overall I'm satisfied with my results. I did just a quick check last night(finished at midnight) with the grounding adapter on/off the car. In my case the car idled smoother and the HIDs were brighter/crisper. The engine did not lug or slow down when the HIDs are turned on. Now take this as you will. I do not plan on dyno'ing either. Just something I did cuz I'm crafty and cheap
Here are the pics
Grounding adapter block
To the valve cover/head
Body. I chose this spot as there is a group of wires.
Block
Alt mount bolt
Crossmember
Old Feb 25, 2006 | 09:19 AM
XclusiveAutosports's Avatar
Nice job!
Old Feb 25, 2006 | 11:09 AM
riceburners2001's Avatar
whats the L bracket made of???(the one on the battery)
looks sweet, makes me want to do it tooo!
Old Feb 26, 2006 | 10:34 PM
jakub2000's Avatar
My battery is in the trunk...how the hell can I do this? Stable idle sound like a good thing to have :-)
Great write-up, thanks a lot!!!
Old Feb 27, 2006 | 03:06 AM
RadioZero's Avatar
i only see 4 wires attached to your battery bracket. you said you used 5 points. where is the 5th attached? did you run it in tandem with anther wire?
home many feet of wire did you need?
advise, thanks.
Old Feb 27, 2006 | 04:53 AM
WalkingDrunken's Avatar
Sorry to hijack but what are the cons to running a grounding system? I have only heard that it might reduce current drag to create a more stable idle but never heard negative consequences except wasting money.
Old Feb 27, 2006 | 06:16 AM
Squeezer's Avatar
grounding kits are a waste of money
Old Feb 27, 2006 | 08:28 AM
S2kracka's Avatar
Waste of money, time, and adds additional weight. Look kinda cool though.
Old Feb 27, 2006 | 09:01 AM
Wisconsin S2k's Avatar
The con to a grounding kit is that it does nothing but add a bunch of wires to your car. You have a better chance of getting more horsepower from a carbon fiber hood than you do a grounding kit.
Also, this belongs in electrical.
Old Feb 27, 2006 | 09:58 AM
That's what I figured, just checking though.
