head removal question
Old Apr 18, 2006 | 07:38 PM
GoFaassttt's Avatar
Default head removal question
I'm about to remove the cam chain sprocket but noticed that there is not enough slack in the timing chain to remove the chain from the sprocket. The auto-tensioner has been removed. Looks like the only way to remove the chain is to first remove the sprocket's hardware and lower it (sprocket) slightly to allow the chain to come off.
Is this normal or is there a step that I am missing?
Old Apr 18, 2006 | 07:45 PM
Slows2k's Avatar
Remove the bolt that holds the sprocket to the head. The sprocket drops down and you can get the chain off, and the sprocket out the top. There is a spacer that goes between the sprocket and the head that will need to be fished out to get the sprocket out as well.
Old Apr 18, 2006 | 07:50 PM
GoFaassttt's Avatar
Thanks again for your help Chris.
Doug
Old Apr 19, 2006 | 04:14 AM
Slows2k's Avatar
eld101
Jul 2, 2017 04:04 PM
Atheist
Aug 17, 2007 10:04 PM
carrera0to60
Jun 25, 2006 10:35 AM
bluesaint
Nov 5, 2005 07:10 PM
Voodoo_S2K
Jul 13, 2005 08:28 AM
