Cleared Corners With Amber LED Running Lights
Old Jan 11, 2002 | 04:50 PM
M3KVB's Avatar
Default Cleared Corners With Amber LED Running Lights
I decided to clear my lights since I had the front bumper off the car to install my new AEM CAI. Many thanks to S2K0 and his tips thread on 12-18-01. If you are thinking about doing it read his helpful hints and photos too. I ended up using the oven method to open up the light housings but found a preheated oven temperature of about 230 degrees for 8 minutes worked the best. Also it is imperative that you use a 1 - 2 inch scraper to help pry the lights apart. I also was especially careful resealing the housings with two seperate coats of black hi-temp silicon which I let cure for 24 hours between coats.
As for the replacement lights for the cleared corner, rather than going with hyper white or blue, I found amber non fading signal lights from autobulbdepot.com which I painted chrome silver leaving a1/2 inch slot on the bottom part of the bulb unpainted by covering it with tape. They work great and look cool. For the running lights I used a replacement amber led which I suprisingly found at Autozone. I have included a photo of the led and packaging. These are excellent and are the best solution to make the clear corners work properly without looking to ricey!!!
Old Jan 11, 2002 | 05:00 PM
4IGS2000's Avatar
Spammer
My experience with LED bulbs is that they do not spread the light beam pattern like standard bulbs do.
Old Jan 11, 2002 | 05:33 PM
momo652's Avatar
You know i really want to clear my corners, but guess i'm afraid to screw somthing up. But that looks awsome, you did a good job. Is possible for you to get a pick with the HID lights on? Just to see how it looks.
Old Jan 11, 2002 | 06:12 PM
M3KVB's Avatar
The led is on in the one photo. They are clear when they are off. They are much brighter at night. By the way, I think just about anybody can cleat their lights, its not that hard. I had the front bumper off and the lights out in about 1 hour!!!
Old Jan 11, 2002 | 06:31 PM
bayarea408's Avatar
looks cool, how long did the whole procedure take?
Old Jan 11, 2002 | 06:38 PM
Takashi KazuMori's Avatar
Good job, nevertheless ... I'm impressed by the quality and output. As for LEDs, I think I'll stick with the conventional Raybirg bulbs for now.
Old Jan 11, 2002 | 07:18 PM
M3KVB's Avatar
I think I could do the whole procedure in under four hours now that I have done it but the first time took about 6 hours total time. Although it is a good idea to let the silicon cure for 24 hours around the housing before reinstalling the cleared lights just to be safe.
darkfx
Mar 31, 2006 06:56 PM
tom717
Jul 13, 2004 02:22 PM
paradiSe
Mar 5, 2004 07:29 AM
secretvampire
Jan 29, 2003 11:08 AM
Anthony
Mar 26, 2002 12:04 PM
