Check engine light
Old Mar 13, 2002 | 04:12 PM
FormerH22a4's Avatar
Default Check engine light
I just picked up my car yesterday and today when I got home from work, I went into the garage to start her up. She started up well but later I noticed that the CHECK ENGINE LIGHT was still on. She sat there a couple minutes in the garage, could the fumes have something to do with it?
Dang, and I just got her too...so many worries when you care so much.
Old Mar 13, 2002 | 07:27 PM
xviper's Avatar
Further to my PM to you, I've just checked the Helm manual. It's #25 fuse you pull for at least 10 seconds to reset the ECM. Make sure the ignition is OFF.
Old Mar 13, 2002 | 09:41 PM
KidK's Avatar
[QUOTE]Originally posted by xviper
[B]Further to my PM to you, I've just checked the Helm manual.
Old Mar 14, 2002 | 01:21 AM
Spanky's Avatar
Before you do anything, take it to the service center and have them perform a diagnostic test first. I had a similar incident where the check engine light came on after work. I had not previously driven the car hard or did I miss shift. The car ran just fine with no unusual noise or any indication of anything wrong. I took it down to get a diagnostic test done and found out to be a problem with the air-pump.
Don't reset it just yet since doing so, you might not get the ecu to read out any codes for the diagnostics to read unless you absolutely know what went wrong.
Hope everything turns out alright.
Old Mar 14, 2002 | 02:27 AM
I'll have to take her in I guess, thanks for the suggestions guys.
Old Mar 14, 2002 | 04:48 AM
Flyin Wedge's Avatar
I'm bettin it's the loose gas cap,same thing happened to me during the first week of ownership.I reset the the light myself.
Old Mar 14, 2002 | 05:13 AM
I took the gas cap off and then put it back on with more than 3 clicks yesterday. I started it up this morning and still CEL. BTW, my S is garaged for a few days, can't take her in due to the weather, S02s aren't kind on snow.
Old Mar 14, 2002 | 11:08 AM
After you tighten the gas cap the light will not always go out.I suppose it could be another problem but my cars running fine for the last four months since I reset the light.
Old Mar 14, 2002 | 01:14 PM
JL's Avatar
JL
I got this problem fixed today.
First, I got the TSB 54 (decel noise from clutch) and 55 (2nd gear grind) work done last week. Everything looked OK driving home. Then, the next morning (yesterday) I noticed the engine check light turned on when I started it. It seemed driving OK. Brought it in today and I just picked it up. The service report says,
Code #P0411 present. Air control system problem. Traced to a disconnected vacuum line. Reattached and rechecked. OK now.
Old Mar 14, 2002 | 01:51 PM
I managed to get it to the dealer and they pulled the code. I don't know the exact code but the serviceman said the description was "too rich fuel" The weather was cold and I let it idle for a few minutes when the CEL first came on or stay on. The weather much have something to do with it???
JimmysS2KPoo
Apr 16, 2007 01:30 PM
Psicho54
Jan 24, 2007 09:40 AM
Elizer
Apr 8, 2003 05:32 PM
Spanky
Jan 26, 2002 05:34 AM
Ed Bean
Nov 24, 2001 06:59 AM
