check engine light blinks on and off when engine is turned on...
Old Apr 7, 2003 | 08:17 PM
Elizer's Avatar
Default check engine light blinks on and off when engine is turned on...
i can't remember, but im pretty sure it used to just turn on then go off, but now it blinks on and off for like... 5 seconds maybe after turn on... is this normal...
but FYI i have really bad memory.
Old Apr 7, 2003 | 08:20 PM
Heyitsgary's Avatar
Mileage? From your description it sounds like the internal 6000(?) service warning. I had that happen prior to my first oil change.
Old Apr 7, 2003 | 08:25 PM
HARDtoTOP's Avatar
Yeah, the instructions to reset it are in the owners manual. If it hits 7500 miles and stays on solid, you will not be able to Vtec until you reset it
Old Apr 7, 2003 | 08:27 PM
lehighwiz's Avatar
is it the 'service engine soon' light or the 'check engine' light? if itis the former, then check your manual on how to reset it.
Old Apr 7, 2003 | 09:50 PM
xviper's Avatar
If it's the Check Engine Light, something is wrong and it won't go off till it's reset. Sounds like it's the Maintenance Required Light.
Old Apr 8, 2003 | 06:38 AM
MacGyver's Avatar
You sure about this one Jeff? I seem to remember running for a short time with the MIL light on without incidence and could still VTEC. I reset it at the next stop I made. Maybe my mind is losing it and it was just blinking right after turn on, not quite to the 'stay on' mode.
Old Apr 8, 2003 | 09:01 AM
HARDtoTOP's Avatar
Yeah, don't know if you remember Bill from Providence. His went on last summer and he lost Vtec. No one could figure out why, then we just reset his light because he was going to anyway. Next thing you know, he was Vtecing again.
Old Apr 8, 2003 | 05:31 PM
Slows2k's Avatar
The MIL will flash on certain occasions. (MIL=check engine light) If the engine is misfiring bad enough to damage the catalytic converter the MIL will flash. The MIL will also flash if the key is turned to on and the car is not started after approx 30 sec or so. If my memory serves me, This is an OBD2 readiness self check. The MIL will also flash when a PGM-FI tester is plugged into the ALDL connector and establishes communication with the PCM.
Old Apr 8, 2003 | 05:32 PM
Elizer's Avatar
thanks a lot i did hit 6000 ill be checking my manual! thanks for da help!
Currahee474
Feb 6, 2007 05:01 PM
Psicho54
Jan 24, 2007 09:40 AM
cvedral
Jun 30, 2006 08:28 AM
jss2k
Dec 19, 2002 11:29 AM
mackyi
Nov 11, 2002 05:19 PM
