H.I.D.trouble..
Old Sep 2, 2007 | 07:50 AM
gerdaland's Avatar
Default H.I.D.trouble..
i have a "rigged" ap2 headlight conversion on my MY00. the passanger side headlight had been blinking for a couple months now and last night it went out. i pulled the headlight and found that i had worn through the ground wire for the ballast. i solder(sp?) it, put it back together and it still wont work. i had spair bulbs, so i tried them thinking that maybe by chance the bulb went out as well. no luck. then i tried listening to see if the passenger side ballast made a noise like usual when i turned the headlights on. the hum usually last 5 second or so but this time it only lasted a second and never turned on. has anyone experienced this or have an opinion on what it might be? bad ballast?
Old Sep 2, 2007 | 11:05 AM
gerdaland's Avatar
im guessing theres nobody ever in the electronics forum...
Old Sep 2, 2007 | 11:58 AM
S2Kstuntin's Avatar
I'm here
Old Sep 2, 2007 | 12:00 PM
gerdaland's Avatar
got any advice?.. should you not solder a ground wire?
Old Sep 2, 2007 | 07:42 PM
S2Kstuntin's Avatar
I don't see that being a problem as I have done it before.
jonmom778
Jun 30, 2016 06:11 AM
AP1Driver
Jul 9, 2013 05:59 AM
r8byb
Feb 16, 2011 02:31 PM
Fizoust
Jan 12, 2010 09:54 AM
buyos1717
Oct 14, 2007 04:54 AM
