Invidia header install With pics and info
Old Sep 30, 2007 | 01:23 PM
S2KPUDDYDAD's Avatar
Default Invidia header install With pics and info
My question is, do you have to remove the motor mount to install it?
Is there a trick to the install??
Thanks
Old Sep 30, 2007 | 01:33 PM
harrrrry's Avatar
I didn't have to remove anything. Once I got the stock header and heatshield off through the bottom, I just put the new one in but just reverse order (from bottom up). I have J's btw, so don't know how different the piping and design is. It's best to do it with 2 persons. It might take some wiggling and forcing. And you might slightly scratch it but..it saves time from removing motor mounts.
Old Sep 30, 2007 | 02:01 PM
Thanks for the reply but, this Invidia header is being a PIA I have instaled a boat load of headers for this car but, this one
Old Sep 30, 2007 | 06:59 PM
skibum's Avatar
Make sure to go in thru the bottom of the car. This will save damage to the valve cover and other scratches. Put a few CLEAN shop towels between any metal surfaces that might scratch.
Old Oct 1, 2007 | 05:44 AM
Thank you but, I have done header installs before on the car. My question refers too the Invidia header specifically and no other just that header.
I know someone has installed this header please chime in.
Old Oct 1, 2007 | 02:55 PM
I'm guessing I am the first on the block to install this Invidia header
Old Oct 1, 2007 | 03:37 PM
BlownAP's Avatar
header install FTL!!!!! Im sorry I cant help. my only advice would to use a lift or get the car very very high on jackstands..... but since you have done them before you already know this..
good luck. report back your impressions... Im still on the fence about this header. I believe it makes No power.......
Old Oct 1, 2007 | 03:39 PM
dean's Avatar
To boldly go where no man has gone before...
Old Oct 1, 2007 | 03:58 PM
skibum's Avatar
Why don't you just get under the car and if it doesn't fit, spend the extra 5 minutes and unbolt the motor mount?
Old Oct 1, 2007 | 04:05 PM
The mount takes more than 5 min. I am asking a constructive question not to be answered by the obvious.
This question is amid at someone who has had experience with this brand of header install.
