Clunk in Reverse?
Old Sep 24, 2008 | 04:11 PM
EOE's Avatar
EOE
Default Clunk in Reverse?
I've searched....
But When I put it in reverse and release the clutch I hear a clink, most deff from Diffy. I don't know what other part of the car could make that noise. Should I worry or is it normal for the diffy to make that noise?
Does that mean I might need new diffy, or is it just gears engaging each other?
Old Sep 25, 2008 | 08:21 AM
INTJ's Avatar
Rear pads clunk often when first backing up. If the diff is toast you will know it and it will get worse.
Old Sep 25, 2008 | 09:37 AM
vincewchan's Avatar
I get that same clunk. I think it's normal? I hope it's normal!
Old Sep 25, 2008 | 03:22 PM
EOE's Avatar
EOE
haha.... okay kool..
thx guys
Old Sep 26, 2008 | 09:42 PM
DBXFX's Avatar
yea i get the same thing when i back up rather quickly.
i found out if you let the clutch out as slow as possible, it doesnt make the noise.
Old Sep 26, 2008 | 11:52 PM
istdercollen's Avatar
it's fine.
Old Sep 27, 2008 | 08:49 AM
jwa4378's Avatar
Wow. I just posted in an identical thread, with the same problem!
Its pretty normal. Still not 100% sure what is causing it. My dealer diagnosed it as "pad shift". They already did the hub nuts (220#ft) and replaced the calipers on the car. Still there.
It ONLY happens to be when changing directions (reverse to forward, or forward to reverse). If it clicks in reverse, if I stop (do not go forward at all), put it in reverse again, I cannot make it make the noise again. It only makes the noise once I apply braking force, while traveling in a direction opposite the way the last time braking force was applied.
John
Old Sep 28, 2008 | 08:22 PM
Jouchan's Avatar
I have the same thing!
Old Sep 30, 2008 | 04:28 AM
billiardboy904's Avatar
JWA, Sounds like your in my shoes.
Try this forum here.
https://www.s2ki.com/forums/index.php?showtopic=635987
EOE, your issue sounds a little different, unless while you were reversing, your momento changed with every blip of the gas. This i could understand while reversing up a small incline.
s2pat
Sep 24, 2012 04:35 PM
jmk9911
Apr 13, 2009 12:41 PM
BigGuy
Jan 28, 2008 05:21 PM
localizer11
Feb 22, 2004 06:44 AM
S2k Dude
Feb 8, 2001 09:19 AM
