New improved V1 stealth mount, results of 2nd attempt
Originally posted by integrate_jh
Does the detector still pick up radar well since it's now a bit hidden?
Jshahan, Yes, it's the same sheet styrene, which I buy in the local hobby store. The stuff is very easy to work with.
E30M, I completely forgot, but I'll make the change when I get a chance.
BTW, While I was doing all this, I discovered that my Alpine alarm system (which never worked right) had a faulty ground connection. Now that I've fixed it, the damned thing works like a charm (it would always go off without any obvious event to trigger it). I share this thought only because it was the only protection I had for the explosed V1 when I parked the car with the top down (so I always put the top up).
where did you get the lucite from? I am interested in trying this (though, based on what you have said about the laser cutting proccess I will more than likely have to do it carefully by hand)
