New improved V1 stealth mount, results of 2nd attempt
Old Jul 7, 2002 | 08:04 AM
Rick Hesel's Avatar
Former Sponsor
Default New improved V1 stealth mount, results of 2nd attempt
Here
Old Jul 7, 2002 | 08:12 AM
iLikeBeer's Avatar
truly amazing!
Old Jul 7, 2002 | 09:01 AM
Stratocaster's Avatar
Rick
Is this "casing out of styrene plastic " the same thing you used on the inside of the Radio/Gauge install as well?
Old Jul 7, 2002 | 09:17 AM
E30M3's Avatar
Might look neater with that skinny, flexible wire idea I posted in your other thread. (posted above)
Stan
Old Jul 7, 2002 | 10:08 AM
integrate_jh's Avatar
Does the detector still pick up radar well since it's now a bit hidden?
Old Jul 7, 2002 | 10:13 AM
anotherbrian's Avatar
[QUOTE]Originally posted by Rick Hesel
[B]Would I recommend that others try this?
Old Jul 7, 2002 | 01:18 PM
Rick Hesel's Avatar
Former Sponsor
There's no way to prove it, but as best I can tell, yes. It is set off by all the store alarms that always set it off before, and the readings work equally well front and rear.
Jshahan, Yes, it's the same sheet styrene, which I buy in the local hobby store. The stuff is very easy to work with.
E30M, I completely forgot, but I'll make the change when I get a chance.
BTW, While I was doing all this, I discovered that my Alpine alarm system (which never worked right) had a faulty ground connection. Now that I've fixed it, the damned thing works like a charm (it would always go off without any obvious event to trigger it). I share this thought only because it was the only protection I had for the explosed V1 when I parked the car with the top down (so I always put the top up).
Old Jul 7, 2002 | 01:30 PM
taylor01's Avatar
Rick,
How about a shot from the back for the rear laser?
Old Jul 7, 2002 | 04:17 PM
Rick Hesel's Avatar
Former Sponsor
There is no rear laser sensor, so the back is completely stock, thus no photos.
Old Jul 7, 2002 | 05:08 PM
Ledfoot's Avatar
where did you get the lucite from? I am interested in trying this (though, based on what you have said about the laser cutting proccess I will more than likely have to do it carefully by hand)
