gps hardwire diy?
there are three spare spades in the fuse box one for constant power one for keyed power (the one you want) and one i think when the lights come on
simply install the ground and then select the proper spade BUT make sure you use an inline fuse
what do you mean by using a inline fuse along with the proper spade?
Device needs to be fused. GPS typically plugs into the "cigarette lighter" port and the GPS plug has a fuse in it. Since you won't be using that plug you need a fuse. Remove what's in there and get a fuse of the same amperage. Or just plug it in the rear of the console and run the cord forward. In the S2000 that plug is ignition controlled.
-- Chuck
-- Chuck
-- Chuck
-- Chuck
kasher_khan
Jan 22, 2018 05:05 PM
for_my_s2k
Jul 27, 2013 06:09 PM
