gps hardwire diy?
Old Nov 15, 2010 | 11:01 AM
KLASMID's Avatar
Default gps hardwire diy?
can any one sho me how to hardwire a gps so that it comes on when the car comes on and turns off when the is turned off?
Old Nov 15, 2010 | 06:26 PM
Bass's Avatar
there are three spare spades in the fuse box one for constant power one for keyed power (the one you want) and one i think when the lights come on
simply install the ground and then select the proper spade BUT make sure you use an inline fuse
Old Nov 15, 2010 | 07:07 PM
oth's Avatar
oth
from the UK technical FAQ, I believe originally courtesy of Modifry
Old Nov 16, 2010 | 08:58 AM
KLASMID's Avatar
thank you guys
Old Nov 29, 2020 | 01:41 PM
Freddy_'s Avatar
what do you mean by using a inline fuse along with the proper spade?
Old Nov 29, 2020 | 02:36 PM
Chuck S's Avatar
Device needs to be fused. GPS typically plugs into the "cigarette lighter" port and the GPS plug has a fuse in it. Since you won't be using that plug you need a fuse. Remove what's in there and get a fuse of the same amperage. Or just plug it in the rear of the console and run the cord forward. In the S2000 that plug is ignition controlled.
-- Chuck
Old Nov 29, 2020 | 04:33 PM
Freddy_'s Avatar
-- Chuck
thank you!
kasher_khan
Jan 22, 2018 05:05 PM
for_my_s2k
Jul 27, 2013 06:09 PM
Predator
Dec 26, 2009 11:12 AM
naseeb
Jun 28, 2006 08:41 AM
xjohnx
Apr 27, 2004 06:24 AM
