roof up and down without using motor?
Old Aug 31, 2008 | 01:38 PM
honda power's Avatar
Default roof up and down without using motor?
i was j/w if i can put my roof up and down by hand without using the motor sry if this is in the owners manual but i dont have one yet i just wanted to check tho before i tug to hard and break something
Old Aug 31, 2008 | 06:07 PM
TYM2FLY's Avatar
YES! However, Page 174 of the 2005 Owner's Manual states "you can close it manually". It doesn't say anyhing about opening it (I would think you just reverse the process, but I could be wrong on that). The manual depicts this as a two person operation, one on each side of the car. The procedure is:
1) Check for blown fuses, replace with same if needed.
2) If it blows immediately or doesn't work, then close manually by;
A. Locate connection for motor & disconnect (lower corner under dash pass side)
B. Hold each corner, raise top & push forward as far as it will go.
C. Then operate the latches as normal.
Old Aug 31, 2008 | 06:57 PM
when it states Locate connection for motor & disconnect (lower corner under dash pass side) are they talking about the fuse or is the roof connected to the motor and u have to disconect it before doig it manually
Old Jul 26, 2014 | 12:02 PM
abroke1's Avatar
they are talking about the wire connector located under far right (passenger side) dash. I tried this but it doesnt work. i dont think a manual operation is possible on a my05 unless you have had some steroids in the recent past.
abroke1
Old Jul 26, 2014 | 07:46 PM
Themikewoo's Avatar
Welcome.
Check out the link in my signature.
abroke1
Jul 26, 2014 11:36 AM
Orpheus
Feb 16, 2013 07:46 PM
ShirleyTemple
May 15, 2011 10:17 AM
oltrollnc
Nov 21, 2004 08:07 AM
astrodog1
Jun 21, 2004 05:09 AM
