S2K soft top not opening fully
Old Jan 8, 2013 | 02:40 PM
louis1's Avatar
Default S2K soft top not opening fully
Hi guys
I have an 2009 S2K and the roof isn't opening fully when it is coming to the end of it travels behind it stays up about 6" it does not go back fully
has anyone got any ideas what might be wrong I took it to the Honda dealer they couldn't find anything I am from N. Ireland can't get in touch with any one here to compare
thanks
Old Jan 8, 2013 | 04:50 PM
stupkid's Avatar
When the top is up do you see the second bar from the front. As the top comes back pull the bar back (it should rotate a bit) all the way until the top is down.
If that doesn't work...
With the top up, check the straps on each side. Should be elastic. If they are torn/loose/etc. replace them with something like modifry straps or oem.
Sent from my SGH-T999 using Tapatalk 2
Old Jan 9, 2013 | 01:58 AM
jonner's Avatar
Pop over to the Irish section and introduce yourself....
Nemui
Aug 15, 2016 11:13 AM
louis1
Jan 10, 2013 04:12 AM
louis1
Dec 4, 2012 10:59 AM
Riviera
Jun 16, 2009 04:31 PM
icen
Oct 29, 2007 11:32 AM
