Transfer- RSX-S to S2000
from internet:
2005 Acura RSX Performance
-1,998 cc 2 liters in-line 4 front engine with 86 mm bore, 86 mm stroke, 9.8 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder
-Unleaded fuel 87
-Fuel economy EPA highway (mpg): 34 and EPA city (mpg): 25
-Multi-point injection fuel system
-13.2 gallon main unleaded fuel tank
-Power: 119 kW , 160 HP SAE @ 6,500 rpm; 141 ft lb , 191 Nm @ 4,000 rpm
2005 Acura RSX Handling
-Four-wheel ABS
-Four disc brakes including two ventilated discs
-Immobilizer
-Spacesaver steel rim internal spare wheel
-Strut front suspension independent with stabilizer bar and coil springs , wishbone rear suspension independent with stabilizer bar and coil springs
2005 Acura RSX Exterior
-Body color front and rear bumpers
-Coefficient of drag: 0.33
-Driver and passenger power heated body color door mirrors
-External dimensions: overall length (inches): 172.4, overall width (inches): 67.9, overall height (inches): 54.9, wheelbase (inches): 101.2, front track (inches): 58.5, rear track (inches): 58.5 and curb to curb turning circle (feet): 38.1
-Complex surface lens halogen bulb headlights
-Heat reflective glass
-Luxury trim alloy & leather on gearknob and titanium on dashboard
-Pearl paint
-Fixed rear window with defogger and constant
-Glass electric front sunroof
-Tinted glass on cabin
-Weights: curb weight (lbs) 2,809
2007 Honda S2000 Performance
-2,157 cc 2.2 liters in-line 4 front engine with 87 mm bore, 90.7 mm stroke, 11.1 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder
-Premium unleaded fuel 91
-Fuel economy EPA highway (mpg): 26 and EPA city (mpg): 20
-13.2 gallon main premium unleaded fuel tank
-Power: 177 kW , 237 HP SAE @ 7,800 rpm; 162 ft lb , 220 Nm @ 6,800 rpm
2007 Honda S2000 Handling
-Four-wheel ABS
-Brake assist system
-Electronic brake distribution
-Electronic traction control via ABS & engine management
-Immobilizer
-Rear limited slip differential
-Stability control
-Wishbone front and rear suspension independent with stabilizer bar and coil springs
2007 Honda S2000 Exterior
-Fixed hoop convertible rollover protection
-Electric softtop convertible roof with glass rear window
-Day time running lights
-Driver and passenger power body color door mirrors
-External dimensions: overall length (inches): 162.2, overall width (inches): 68.9, overall height (inches): 50, wheelbase (inches): 94.5, front track (inches): 57.9, rear track (inches): 59.4 and curb to curb turning circle (feet): 35.4
-Projector beam lens Xenon bulb headlights
-Luxury trim alloy & leather on gearknob, leather on doors and alloy look on dashboard
-Pearl paint
-Weights: curb weight (lbs) 2,855
[B]
-Unleaded fuel 87
-Four-wheel ABS
-Immobilizer
-Pearl paint
-Four-wheel ABS
-Immobilizer
-Stability control
-Pearl paint
[B]
Originally Posted by versionJDM,Mar 1 2007, 08:39 AM
you do realize that the F20 has forged interals whereas the K doesnt right? you do also realize that its been doucmented 100 times that the f20 responds to mods just as well as K's except for cams?
i do agree on the comfort thought, the s2 is sure no G35c, but then against it was never suppose to be.
oh, and the only time a RSXS will be a stock s2k from a roll is when its got I/RH/E/Kpro and then is it really still a drivers race from a roll. modded s2ks have NO problem with modded DC5's, atleast i dont.
Stoopid Fast racing has put down over 700 on stock k20 and k24 blocks...
And except for cams is correct...but this makes a HUGE difference!
Lets compare the number of all motor s2k's running 12's to all motor rsx's running 12's....RSX by far, mods are cheaper, and its more mod friendly.
I love my s2k, but i just have some issues with it
. I havent had a problem with any RSX's in a race before either...but their are more fast RSX's than their are S2000s for sure.
It still shocks and upsets me that the S2k is such a heavy pig for what it is.
The Miata has gone the bloated route, too, these days.
Is it really that difficult to build a sub-2,500lb. roadster?
The Miata has gone the bloated route, too, these days.Is it really that difficult to build a sub-2,500lb. roadster?
Originally Posted by joosyjoos,Feb 28 2007, 10:27 PM
hey guys first post on the forums...
I currently drive an Acura RSX type S. I love the car to death but my lease is running out and im thinking about a new ride. So naturally... loving my honda product im looking at the S2000.
Not many bad things i really hear about it... but i do hear about how the driveability sucks. Now coming from an RSX Type S im used to the complete lack of torque downlow... but love the way it screams in vetch. Is the slight bit of torque that the S2000 delivers over the RSX type S (2004) noticable at all? I mean... the cars weight about the same but how do the engines compare downlow? Id like a bit more torque but its no big deal really if its just as bad cause Vtech makes up for it in my mind.
Also... one thing i hate on my RSX type S is the huge turning circle.... im wondering how good/bad the turning radius is on S2000.
Lastly... how bad is road noise? Ive never owned a convertible before. Any other problems with the top?
How does the 6 speed compare with the one in the RSX Type S?
Obviously only people that have really driven both can comment but im guessing im not the only cross shoper between the two cars...
Thanks... appreciate the feedback and sorry if this is searchable... it didnt really turn up what i was looking for.
To answer your questions...
To me, the driveability is better in the S. Of course you are going to have road noise, it's a convertible... but this is an enthusiast's car and is meant to have fun, not to reduce road noise and look fancy.
The torque on the AP2s will be a noticeable difference from the Type S... figure you are going from around 140 to about 162. The gearing though is what really makes up the difference. Finally, if you think the Type S screams in Vtec, the S2000 will be a loud car for you. Stock they are about as loud as a Type S with an intake. The S2000 is in another league, and if you get one, you will soon find out why.
Originally Posted by enigmadsm,Mar 1 2007, 10:17 AM
Can you tell me what the most power ever put down on a STOCK BLOCK f22 or f20c has been?
. I havent had a problem with any RSX's in a race before either...but their are more fast RSX's than their are S2000s for sure.The K series does respond well to mods, but so does the F series... it just has to be done the right way. If you slap on another duel exhaust, you are not going to gain much. If you go single, it has just as good gains, if not better than a Type S cat back upgrade. In fact, K series with I/RH/E and Kpro dyno tuned is good for between 200 and 210 whp. F Series with I/H/E and simple VAFC is good for 220-230 rwhp.
My point is there is a lot of ignorance out there regarding the F series. I am not saying you are one of them, because you sound like you know what you are talking about. I just get tired of going to clubrsx and reading about how an RSX with just a CAI put car lengths on an S2000.
The K series is an amazing engine... but so is the F series.
If they could, they would. It would probably be a lot more expensive too, due to extensive use of aluminum.
The S2K is a lightweight relative to most cars on the road these days.
Originally Posted by Whitedeon8,Mar 1 2007, 10:46 AM
Jason (St00pid) tuned my old car (RSX) and does have a lot of experience tuning the K series and F series. Yes, he has extracted that much power from the K series engine, but how long do they last? If you want to play that game, let's compare the number of turbo failures on the K series and the number of failures on the F series. The K series with a turbo in a lot of cases is a bomb waiting to explode. Phil, a guy here who has the highest output supercharged S2000 has been making over 500 rwhp for several years without one problem.
I think my main problem is just getting burnt out on driving the S everyday...i have my evo too, but thats not much better haha. i mean it has way more room, but the suspension will chatter your teeth away.
To the OT, its a tough choice, but aint nothing like having the top down on a nice sunday drive.
As far as the transmission, I always read and heard about how great the RSX's tranny was. It is my opinion that compared to the S, the RSX feels like crap; like shiftin gwith a wooden spoon in a bucket of cold oatmeal (I'm exaggerating here, but really, the S2k's transmission is top notch)
to the original poster. its very simple. the s2000 is faster, more fun, harsher, louder, less practical.
i've driven many rsx-s. it is a good lil car for its segment. its very practical and reliable. the s2000 is a diff animal. it is a specialty vehicle that can be treated as daily driver if it needs to be.
imo, stop worrying about the differences. once u get in the car, u will know if it is for you or not. i would say within 15 min test drive, u'd know. it's a love it or hate it car. if you r too big, if u need practicality, u wont love it.
the mod question that most of the internet folks argue about doesn't come into play for 80% of the people out there. u can always out mod someone, on any 2 cars so there's no pt in arguing.
its good to prepare while u r reading on the internet. but with the s2k, there's no substitute for a test drive. even if u r a passenger, u wont really know what a s2000 is like.
after first 2 times of driving the ap1 s2k, i couldnt stop thinkin about it. i drove a $50k lexus coupe at the time and all i could think about was this honda roadster. i'd come on this board & read other ppl's experiences just to reminisce about my limited experience. 3 years later, when i got rid of the lexus, there was just 1 car for me and i went out and got it
