2.7 L Stroker Dyno....
Old May 27, 2007 | 09:12 PM
  #51
SPECIAL-OPS-S2K's Avatar
you could possibly run 50/50 Water/Meth injection on regular 93 octane street gas which is like running 110 octane race fuel all the time and street this setup without the issue of $7/gal fuel
Old May 27, 2007 | 09:16 PM
  #52
SilverKnight's Avatar
So no local tuners could do the install then? Unbolt the engine and send to VA sounds like?
Old May 27, 2007 | 11:18 PM
  #53
Project22a's Avatar
Even if it only made 280whp/220wtq on pump, I'd still be grinning to no end.
Old May 27, 2007 | 11:19 PM
  #54
MB's Avatar
MB
Member
Id still like to know how the reliability is being addressed!
Old May 28, 2007 | 09:04 AM
  #55
Silver9k's Avatar
You guys have to realize that IP built this particular motor as basically an all out race motor. The compression ratio on this motor is pretty damn high, so I don't think that IP would want to run street fuel in it. I'll leave it up to Ya to give out details.
Old May 28, 2007 | 09:37 AM
  #56
sabry's Avatar
Please reply to my PM because i'm really interested.
Best regards
Sabry
sabry.freh@gmail.com
Old May 28, 2007 | 12:36 PM
  #57
FF2Skip's Avatar
Uhhh... they just built it. Time/mileage is the only way to substantiate such info.
Then again, I'm tracking my 2.5L and have had no problems. Rod bearings pulled after a couple of events- no wear at all.
Old May 28, 2007 | 10:35 PM
  #58
Paper Lawyer's Avatar
What have you set your rev limit to Skip? I should remember as I've read your posts many times, but I have a memory like a sieve
Old May 29, 2007 | 02:40 AM
  #59
FF2Skip's Avatar
It's set to 9100 rpm, however, the power starts to fall around 8500-8600 rpm(needs a bigger cam). I usually shift there on the track. I do have the extra rpm's to hold a gear if need be, thereby saving a shift.
Old May 29, 2007 | 03:00 AM
  #60
MB's Avatar
MB
Member
Yes im well aware of that but as an engineer, you can see what potential weaknesses are as a result of a change, and do something to adres them accordingly. My question is around the thinning of the cylinder walls and their ability to cope with the increased frictional heat.
What I didn not ask is how long it will lass (not quantifiable without testing) which you have presumed I have asked.
