ASM Overfenders
[QUOTE=the s2k dude,Aug 11 2008, 10:24 PM] ill be running 17x9 + 40 all around and 255/40/17 tires with my front and rear asm stuff. its not going to be as aggressive as nichigo in the back.. but its non staggered and safe.
Originally Posted by han racer,Aug 11 2008, 05:09 PM
thanks nichigo i think im gonna end up going with ur setup!
- -3 Camber
- Relocate bumper bolt
- Cut and re-weld rear quarter panel
- Cut ASM over fender so that it has ZERO lip
- Trim rear bumper
- Pull rear bumper out to become flush with over fender...this is probably the most important step...you will not be able to clear if you do not pull out your rear bumper.
Not to discourage...just want you to know what you're in for. In fact, expect problems to come up even if you do all of these things. It's not an exact science. Even if you get the same tire specs, tire widths tend to vary between brands. You're pretty much bordering the limit here, so if there's any room for error, a small difference in width can mean alot.
I would not have done this setup if TE's came concave in a different offset. Unfortunately, +22 is the highest that they become concave. Ideally, I would have run a +30 or +35 in the rear.
Originally Posted by han racer,Aug 12 2008, 09:42 AM
ah jeez....square one again....
what are the specs on the ASM street car? thatd (theoretically) be the best setup right?
Wheels: 17x8 Prodrive GC-010G
Tires: Bridgestone RE-01R, 245/40ZR17
Originally Posted by medicalstudent,Aug 12 2008, 12:54 PM
yet they get the job done
I'm running:
Front: 17 x 8.5 +42 on 225/45R17 RE01R
Rear: 17x9.5 +42 on 255/40R17 RE01R
I'll try and get a pic of what this looks like.
I only have the rear over fenders. I didn't relocate the bumper tabs and the tire is rubbing on that now.
The fronts are normal unmodified fenders. But the plastic tabs that holds the splash guards are gone due to tyre rubbing.
