cusco 4pt install help.
i need to vent:
how the **** do you get the cock sucking, mothert****ing piece of ****ing shit tray out of the god damn car? what the ****!!!!!!!!! for 2 ****ing hours i tried to get that god damn plastic tray out of the ****ing car and i cant. even after i was pissed i tried to just ****ing break the thing and it would even break. ****!
whew. thanks.
so now for mature converstaion:
how do you get that tray out? the instuctions are in jap and the pic are vague. i popped about 100 clips and it wouldnt budge. plus my drill bit suck and could make it through the floor boards.
help!!!!
whew. thanks.
help!!!!
So did you get the tray out. It was a pain when I did mine. There were 2 clips one on each side that I could not see. Once I found them it popped out. If I remember right I got to them from inside the trunk underneath.
Yeah, you will need a solid drill bit. Drilling inside the trunk on the uneven surfaces with little room to press down is not fun either. Get a slighty oversided bit.
Hope this helps a little..
Originally Posted by versionJDM,Aug 18 2007, 04:49 PM
i need to vent:
whew. thanks.
help!!!!
whew. thanks.
help!!!!
the way to get there is via the trunk and removing the spare and putting side the trunk lining.
is a small space but in there you can see with a light how the tray is in. the 2 hardest screws to me where the plastic ones on top of the 2 corner pieces but you may not have to remove that.
i popped the corner screws, that have the big black heads on em. i also popped the clips that are on the far side of the tray under that factory hoops, there was four of them i think.
for two hrs, i just could get it out! help!
Originally Posted by alejo,Aug 18 2007, 10:41 PM
once everything is off it pops upward by hitting it from below. if you removed all the screws - not just the clips it will pop off.
where the tray meets the factory roll bar hoops. i popped the 4 clips on the tray.
where the tray extends back and meet the trim under the glass window. i unscrewed to screws with large black heads.
the tray is loose on the sides, i can get my fingers under it and pull it upward but it seems to be will attached in the middle sections still. i cant any other clip screw other than those.
thanks for the help so far... if i can get this tray out, i can put this damn thing in tomorrow!
