cusco 4pt install help.
Old Aug 18, 2007 | 03:49 PM
Johnny Sack's Avatar
Default cusco 4pt install help.
i need to vent:
how the **** do you get the cock sucking, mothert****ing piece of ****ing shit tray out of the god damn car? what the ****!!!!!!!!! for 2 ****ing hours i tried to get that god damn plastic tray out of the ****ing car and i cant. even after i was pissed i tried to just ****ing break the thing and it would even break. ****!
whew. thanks.
so now for mature converstaion:
how do you get that tray out? the instuctions are in jap and the pic are vague. i popped about 100 clips and it wouldnt budge. plus my drill bit suck and could make it through the floor boards.
help!!!!
Old Aug 18, 2007 | 04:50 PM
vvs's Avatar
vvs
So did you get the tray out. It was a pain when I did mine. There were 2 clips one on each side that I could not see. Once I found them it popped out. If I remember right I got to them from inside the trunk underneath.
Yeah, you will need a solid drill bit. Drilling inside the trunk on the uneven surfaces with little room to press down is not fun either. Get a slighty oversided bit.
Hope this helps a little..
Old Aug 18, 2007 | 06:12 PM
alejo's Avatar
Originally Posted by versionJDM,Aug 18 2007, 04:49 PM
i need to vent:
whew. thanks.
help!!!!
there are a couple of 10mm screws underneath that go into the area of the center consel.
the way to get there is via the trunk and removing the spare and putting side the trunk lining.
is a small space but in there you can see with a light how the tray is in. the 2 hardest screws to me where the plastic ones on top of the 2 corner pieces but you may not have to remove that.
Old Aug 18, 2007 | 09:25 PM
i popped the corner screws, that have the big black heads on em. i also popped the clips that are on the far side of the tray under that factory hoops, there was four of them i think.
for two hrs, i just could get it out! help!
Old Aug 18, 2007 | 09:39 PM
i just cant see where the hell you get this thing out? i searched and searched but couldnt find a DIY.
Old Aug 18, 2007 | 09:41 PM
alejo's Avatar
once everything is off it pops upward by hitting it from below. if you removed all the screws - not just the clips it will pop off.
Old Aug 18, 2007 | 09:48 PM
ok. so if your stand at the back of the car looking forward:
where the tray meets the factory roll bar hoops. i popped the 4 clips on the tray.
where the tray extends back and meet the trim under the glass window. i unscrewed to screws with large black heads.
the tray is loose on the sides, i can get my fingers under it and pull it upward but it seems to be will attached in the middle sections still. i cant any other clip screw other than those.
thanks for the help so far... if i can get this tray out, i can put this damn thing in tomorrow!
Old Aug 18, 2007 | 09:50 PM
SDUECE's Avatar
So did you get it out yet? It looks like you got all the clips. Are you just having a hard time getting it through the rool hoops?
Old Aug 18, 2007 | 09:52 PM
^^^ no it still in the car. i gave up and took the rest of the night off before i got mad and busted something like a moron.
Old Aug 18, 2007 | 09:56 PM
SDUECE's Avatar
I don't think there is anything else holding the rear tray in. You have to pop it out from under the spare tire side. Then go back inside and pull the tray out.
