F20C to the Max
#61
Update on my build and my FINAL decision on what parts to use.
MY C/R will be about 13:1 using Mahle gold series honda prelude pistons with Carrillo pro-A rods with the stock crank micro polished and possibly knife edged. I will need a 2mm headgasket to drop compression and to allow for enough clearance. I've been running calculations for a good month or two to make sure everything numerically works out. If i ended up doing the build and the clearances aren't enough then it's no sweat and I'll just ditch the pistons and go with the Toda pistons and call it a day.
#64
Sweet, mugenrio it looks like we are rio brothers Was your header dyno done with no mods or did you have other parts at the time? I put extensive mods up there since it looked like you had a lot on the car, if it were stock and then you added header then I will change it. Thanks for the info.
#66
AEM FPR
Stock OD TP
Set of hi flow turbo mufflers that replaced the stock mufflers
And a Spoon snorkel
NOTE the dyno plots show the difference just from installing the header and then the difference once the A/F were changed by way of adjusting the fuel pressure.
SO instead of looking at just the raw numbers look at the % gain between before and after.
#68
Some of those mods are long gone some were one off custom pieces I was road testing, namely the exhaust for a buddies Race S2000( Driver ok but car was totaled in a race a couple of weeks after putting on the exhaust.)
+ It was just to loud for the street.
I was back on my stock exhaust + the turbo mufflers when I installed the Mugen header.
Current mod list is way longer then that one was.
chopper-world
06-01-2008 01:32 PM
