F24 Build
Originally Posted by carrera4,Dec 31 2007, 10:34 PM
It's a straight up copy of the Hytech.
How did you get around the wall lining issue? I was wanting to do the same buildup but the whole lining issue scared me away because i didn't have the cash to sleeve it
. If you do i would love to see your setup. Even though i sold my itbs 3 weeks ago I still have a f20 laying in my garage waiting to be built
btw do you live in ohio?
If you do I would love to see your build up.
Originally Posted by Popeye,Jan 2 2008, 03:38 AM
Do they have experience with the F20C or are you the 1st ?
Maybe a stupid question, but are you able to keep the oil squirters? It seems that with some of the strokers out there, you have to block them off.
OK, went back and read the article again, it says they can be used if you modify the nozzle. I would assume an interference issue with the big end of the rod? How did you handle this?
Good job by the way and good luck. Hope it turns out well. I think there will be a lot of people following your lead if so.
Originally Posted by kial007,Jan 5 2008, 01:58 PM
I didn't try to mock up the bottom end with the squirters in but I did put one squirter into the block when it was bare. I couldn't tell from this whether or not there would be interference with the big end of a rod but the squirter nozzles are angled and with the increased rod angle, the rod beam would be very close to coming into contact with the nozzles. This is why they were plugged.
