I/H/E AP2 power
I am going to purchase the Invidia V3, test pipe, FIPK, Emanage ULT.
I was wondering if it would net me more power if I went with the 70mm test pipe, or stuck with the 63mm Berk, or the 60mm Invidia?
as far as switching to 70mm tp, i don't think it'll do much if your exhaust is not 70mm and even then probably not much if you're running an oem or smaller than 70mm header.
Originally Posted by toofast4yalll,Aug 26 2007, 11:24 AM
ebeldesign - That A/F ratio needs major work. Doesn't look like there's much power left on the table up top, but your midrange would get a nice bump. I would go with an EMU.
Originally Posted by sleeper_s2k,Aug 31 2007, 03:12 AM
i'm basically running a 70mm exhaust with berk's 63mm tp. i'm ok with this setup for now but if ever got the j's header, i'd definitely switch to a 70mm test pipe to avoid the bottle neck.
T1R 70mm V3
K&N FIPK
AUT cooling plate
Greddy Emanage Ultimate and P&P harness
No header yet, I am not sure which one I am going to purchase quite yet.
Originally Posted by S2Kstuntin,Aug 31 2007, 09:18 AM
I finally talked some sense into myself and ditched the Invidia. I purchased the following:
T1R 70mm V3
K&N FIPK
AUT cooling plate
T1R 70mm V3
K&N FIPK
AUT cooling plate
Andre
Originally Posted by 8kGoodENuff,Aug 31 2007, 09:31 AM
Please keep us updated on this when you get a dyno cause that is the setup I have planned.
Andre
Andre
David
