Js Intake and ASM Hood
Old May 29, 2008 | 05:02 PM
LostMotion's Avatar
Default Js Intake and ASM Hood
I have heard from one person that the hump on the ASM hood is not tall enough to clear the Js intake. Anyone actually tried? Thinking about switching my Mugen counterfeit out for the Js.
Old May 29, 2008 | 06:05 PM
Randizzle88's Avatar
it will work. that hood is made for the asm intake. also the asm intake is a little bigger then the j's so im pretty sure it will work.
Old Jun 2, 2008 | 04:29 PM
Taseas's Avatar
@Carrera4
What sort of benefit are you looking for? I am asking because i use a Mugen style intake myself. One thing that i noticed, apart from the smaller sized filter (which is a bad thing obviously) is that it is designed to resonate some sound under 6K which i do not know how it translates into peroformance...
Old Jun 2, 2008 | 08:03 PM
shox's Avatar
The snorkle will fit but there is slight rubbing with the hump part of the intake with the hood vent. AJ-R has the same issue as I do, unless you slightly cut the underside of the hood there will be some rubbing but nothing serious.
Old Jun 2, 2008 | 08:17 PM
scutrCR's Avatar
not to jack your thread but....can you fit the J's intake with stock hood? if you do some cutting obviously?
thanks
Old Jun 3, 2008 | 01:17 AM
Taseas's Avatar
thanks
Yes you can, you just have to cut it a bit, just like you do with Mugen intake.
billyzane
Nov 22, 2007 08:54 AM
billyzane
Nov 5, 2007 07:50 PM
dagostino777
Apr 17, 2007 10:13 PM
tantheman
Dec 5, 2006 07:09 PM
medicalstudent
Oct 24, 2006 11:22 AM
