Toda's F20C
I thought Toda was producing engines years ago? was I dreaming?
Also, with the difficulty in rebuilding these engines due to the FRM cylinder walls what options exist for the F20c now that Honda isn't producing bottom ends at this point? Do we have any options less than the $16k and a year long wait from Spoon Sports?
Yeah I just do not get that. I mean, even built, what is the capability comparison between that and a built K24? I guess maybe some still want to keep the "original" motor but if you are modifying and building the motor none of that means anything. I have not looked into the power handling of these built versions vs a k24, but you can also replace said k24 for a fraction of the F20 if you blow it up, which you will eventually if doing huge builds
Toda Just announced their F20C
https://motor-fan.jp/weboption/article/15343/.
I wonder how this matches up to the J's and Spoon Engines
Looks epic. Such a long stroke 99mm with just a 1mm oversized bore (87mm). 8 grand max rpm as a result. Would probably hit that all day long without issue. Toda is hardcore!
J's and Spoon both build their engines using Toda rotating parts as far as I know. Would love to see how this Toda unit compares.
s-duces
10-25-2002 06:57 PM
