Stroker kits
Old Feb 28, 2006 | 07:23 PM
  #61
suterusu's Avatar
Originally Posted by S2000_Europe,Feb 27 2006, 04:31 PM
99 mm crank and 90 mm bore
ummm, have you seen the space between cylinders, even with the stock 87mm bore? This is going to come off sounding like I'm an asshole, but I think the 2.5L stroker is a pretty stupid idea. I'm not sure what they were thinking when they came up with it besides bragging rights.
Even with a closed deck (I'm not sure if the IP is or not) you are taking what little meat there is left between the cylinders down, and on top of that adding a huge amount of side loading on the thin walls with that 99mm stroke. Just stupid and for bragging rights.
Thats one thing that turns me off from the 100mm 2.4L stroker. There is a large amount of stress on the "power" side of the cylinder in an engine that was designed to have very little stress in that direction. If I were to ever do it, I'd probably go with the ERL SuperDeck and stock sized bore because you'll need all the strength you can get. I'm anxious to see how the ASM 2.4L engine continues to fair under race use.
EDIT: Just went and measured, the spacing between the cylinders is ~7.5mm, so boring it out to 90mm takes 1.5mm off each side leaving you with ~4.5mm seperating each cylinder. That's just nuts.
Old Feb 28, 2006 | 07:43 PM
  #62
suterusu's Avatar
Originally Posted by Trip,Feb 27 2006, 05:14 PM
Bore = 87mm
Stroke = 92mm
((3.142 x ( (bore/2) x (bore/2) ) x Stroke) x 4 cylinders) / 1000
((3.142 x (43.5 x 43.5) x 92) x 4 ) / 1000
(3.142 x 1892.25 x 92 x 4) /1000
2187925.416 / 1000
2187.92CC
sorry to nitpick, but the F22C has a 90.7mm stroke, not 92. Bore is the same as the F20C at 87mm. So, the displacement is 2156cc.
Old Feb 28, 2006 | 11:24 PM
  #63
Trip's Avatar
Did i mention this is a F22C ??
Old Mar 1, 2006 | 08:07 AM
  #64
suterusu's Avatar
When you quoted Birdie, he was asking what the bore and stroke was on the F22.
Old Mar 1, 2006 | 11:56 AM
  #65
Trip's Avatar
He also asked how to calculate displacement, hense my odd working formula
I should have specified that the # used are just to illustrate the formula
Old Mar 1, 2006 | 01:58 PM
  #66
suterusu's Avatar
oh, my bad.
Old Mar 1, 2006 | 03:17 PM
  #67
Birdie's Avatar
2.4 liter is going to rock ! lets wait and see!
Old Apr 23, 2006 | 01:00 AM
  #68
Trip's Avatar
I found another stroker Kit off the shelf which can rev up to 9000Rpm
CR is unknown.
Tracy sports
http://babelfish.altavista.com/babelfish/t...01%2FAP10007%2F
Old Apr 23, 2006 | 06:41 AM
  #69
Jekyoo_Style's Avatar
CR is unknown.
Tracy sports
http://bulletproofautomotive.com/cat...il.php?ID=4231
I'm sure if anyone is interested, Ben or ..Ben can answer questions about it.
Old Apr 23, 2006 | 02:33 PM
  #70
Trip's Avatar
From the looks of it TracySports offer 2 stroker kits.
A) Ap2 specs >assuming revs to around Ap2 specs
http://babelfish.altavista.com/babelfish/t...01%2fAP10006%2f
B)2.2Ltr which can handle 9000rpm
http://babelfish.altavista.com/babelfish/t...01%2fAP10007%2f
