Throttle Body Options
Originally Posted by gernby,Apr 15 2010, 08:42 AM
I don't see any TB's on InlinePro's website.
When I bought a big bore TB for my '91 Integra, I had to increase the size of the intake manifold opening myself. I just stuffed a towel into the IM, drew the target size on the mounting surface, then started grinding away. Once the opening was slightly bigger than the TB, I stuck a vacuum into the IM to get as much of the shavings as I could, then pulled out the towel, then stuck the vacuum hose in again.
Originally Posted by ap1_tot,Apr 12 2010, 12:29 PM
^^ Thanks man. great idea. So the stock port diameter of our Intake Manifold is maybe around 67mm? Any details on this one? I just assumed its 67mm since you said that it requires little to no porting wit the Blox 68mm throttle body.
http://www.bloxracing.com/product_info.php...&products_id=18
Is this the exact product? I need to know because I wouldnt want any confusion in ordering. Shipping stuff to my country sucks bigtime.
The stock manifold is around 67mm wide. When you mate the throttle body up to the manifold, you will only see little parts that stick out from the manifold. You can just use a sharpie and grind those parts down.
