tuned...
Old Jan 11, 2010 | 01:13 AM
s2konroids's Avatar
Originally Posted by BulletProofAuto2,Oct 28 2009, 07:43 PM
Do you have a dyno sheet?
Dynos should be used as tuning instruments, not as peak number finders. There are so many different variables with dynos that you should not compare graph to graph with different dynos.
What you should be concerned with is making sure your air/fuel ratio is set correctly, and how usable your power is. Look at the area under the curve, not just the peak numbers. When I had my car dynoed we sacrificed top end power for more midrange, because that's where the power was most usable.
-Colin
Couldnt of said it better myself.
about midrange well more usefull on the road if thats your bag.
Old Jan 11, 2010 | 06:45 AM
AFs2k's Avatar
I had an intake and test pipe and got 223 and 160 on a dyno jet after my tune. Once Vtec was lowered a bit it was on. I think I gained like 15+ in midrange. I will post up the sheets from untuned to tuned once I find them.
Now I have a exhaust and I want to get it retuned.
Old Jan 11, 2010 | 06:54 AM
fenixv8's Avatar
you'd prob make more power with a stock header over a DC one, get a better header and a more free flowing exhaust.
Old Jan 11, 2010 | 03:24 PM
RIDGERCR's Avatar
A hi-flow cat or cat-delete will certainly add power, not to mention shave weight.
Of course, plan on a new dyno tune after changing out these parts. Your results should be good.
NexS2000
Sep 27, 2008 06:57 PM
thecbrman
Oct 26, 2006 07:58 PM
CMiS2K
Jun 21, 2003 03:00 PM
hyperpm
Sep 11, 2002 07:35 AM
