What are the specs of the Amuse S2000?
Old May 11, 2005 | 06:19 PM
  #61
Xplosiv's Avatar
Spoon is pretty garbage comparing to J's and Mugen.
I gave the above statement based on two catagories: funtion & quality.
Old Jan 8, 2006 | 03:26 AM
  #62
jakub2000's Avatar
Since I had and have a "few" SPoon part on my car, I can't agree that Spoon is any lower in quality than Mugen.
What makes you say things like that?Does a Spoon header make less power than Mugen?Or is it a low quality product without show-quality?
Old Jan 9, 2006 | 03:55 PM
  #63
pfds2k's Avatar
I thought the Amuse wheels were 17x9 +40 not 17x9 +63? +63 can't clear Endless brakes can they?
Old Jan 23, 2006 | 09:23 PM
  #64
ITRbroham's Avatar
I dunno' if you guys know but Tanabe-san, owner of Amuse, personally tunes the engines and suspensions of the cars he builds.
Old Jan 25, 2006 | 05:17 PM
  #65
suterusu's Avatar
Amuse wheels, at least the CE28N, has always been a 17x9" +40 offset all around. Even before they had the BBK on their car, they did this for a wider track. They run either 255/40/17 BS RE-01R (Touge/Street) or Advan A-048 tires (track).
They used to run a 16x8" TE37 with staggered offset, I forgot what exactly they were though. Something like +45 front and +42 rear?
Toe, from what I can tell, has been set pretty mild to 0 in the front, massive toe in for the rear. Camber is set rougly -3.5* front and -4* in the rear.
Their most current set up is:
Mugen intake
Amuse ECU
GReddy/Trust Iridium spark plugs
Mugen thermostat and fan switch
ARC radiator/radiator cap
ARC GT-R oil cooler
Amuse R1 Header
Amuse R1000 70mm exhaust
Cusco catch tank
Amuse/Bilstein coilovers (7K/8K Touge/Street, 12K/14K Track)
'04 rear subframe (and maybe suspension arms?)
Amuse R1 front upper arms
4.5:1 final gear
Cusco 1 way LSD (Amuse SPL settings)
Amuse/Endless R1 BBK
Amuse R1 pads
Removed airbags, sound deadening, tools/jack/spare, and soft top.
Personal Pole Position steering wheel
Two Recaro SPGs
Takata 4pt harnesses
Mugen(?) roll cage
Amuse 300km/h speedo conversion
Defi water temp, oil temp, oil pressure
Amuse R1 front bumper
Amuse carbon hard top
Amuse carbon hood (race version, with hood pins)
Amuse carbon trunk
Amuse carbon GT wing (with new gurney flap on the rear)
Craft Square carbon GT mirrors (painted)
Stock front fenders, lip rolled out.
Stock rear fenders, slightly rolled.
Volk CE28N 17x9" +40 Titanium Silver
Weight ~2510lbs.
Tskuba best time 1'02.XXX"
Old Jan 25, 2006 | 08:36 PM
  #66
ej0513's Avatar
^ good info right there.. but i could have swore that i saw it was running a 4.3 FD.
Old Jan 26, 2006 | 07:53 AM
  #67
suterusu's Avatar
I believe they used to run the 4.3, or maybe it was MCR. I know MCR was running a 4.3 in the BMI Battles At 10,000RPM video.
The 4.5 final gear is as of the latest BMI and Amuse's website.
Old Mar 11, 2006 | 01:25 PM
  #68
#Amuse#'s Avatar
And what about the non staggered wheels set up?May be ill go with it.
Old Mar 11, 2006 | 03:57 PM
  #69
ITRbroham's Avatar
You fellas realize the the latest Amuse "Touge Monster" is an '04 spec S2K?
Old Mar 11, 2006 | 04:39 PM
  #70
spoons2000boy's Avatar
Are you shure? I know in the last part I saw they put a 04 up rear subframe on to battel the higher out put cars.It was the same car thet has always been run.
