Headlight problem
Old Nov 23, 2013 | 04:46 AM
s2k tony's Avatar
Default Headlight problem
My headlight on the right hand side as your looking at the car does not work. I've tried new bulbs, fuses, checked the relays and its none of those. I now think it may be the ballast box. Is it possible to switch the ballast boxes over to see if it is that? Or is there an easier way to check if the ballast box is working?
Old Nov 23, 2013 | 05:16 AM
Rays S2k's Avatar
Have you checked to see if you have power going to the ballast
Old Nov 23, 2013 | 06:38 AM
s2k tony's Avatar
No I didn't as I don't know how. It is defiantly the ballast box though as I tried the good one on the side that wasn't working and the light worked fine. Any idea on where I can find a ballast box?
Old Nov 23, 2013 | 09:36 AM
Rays S2k's Avatar
The ballast box is attached to the Headlight on the bottom
Old Nov 24, 2013 | 01:39 PM
w1ngman's Avatar
Ballasts can definitely be swapped across from one headlamp to the other to rule out / conclude a failed ballast.
05berlinas2k
Jun 29, 2007 06:22 PM
s2kev
May 21, 2006 01:22 PM
s2kev
Apr 18, 2006 11:58 PM
S2_Gider
Dec 2, 2005 06:09 PM
bhav
Aug 14, 2004 07:16 AM
