Help! Check engine light!
Old Aug 23, 2010 | 04:50 PM
Cid00x's Avatar
Default Help! Check engine light!
So this morning I started my car to go to college and I noticed the check engine light came on. So I checked my clutch pedal and all my fluids, and any wires, and the cold air intake and the exhaust manifold and all that stuff, and nothing was wrong, so I drove, and the gear changes were fine, the engine was responsive, the steering was responsive, and the sound all together was normal. It sounds fine. It feels fine.
So really, is anything even wrong? It is running fine, and my oil levels are fine. Everything is the same, apart of the check engine light in the dashboard.
Is it a fluke? I even had to fellow s2k owners look at it, and they did not find anything wrong.
Old Aug 23, 2010 | 05:02 PM
.eric.'s Avatar
Did anyone use a scanner and check for codes?
Old Aug 23, 2010 | 05:07 PM
TopGear's Avatar
Take it to an autozone. They'll scan the code for free. Could be a million different things without knowing the code.
Old Aug 23, 2010 | 05:26 PM
Budman05's Avatar
My mother goes there once a week to reset her VW, because she doesn't tighten the fuel cap.
Old Aug 23, 2010 | 05:30 PM
w1ngman's Avatar
First things first...if the CEL is blinking then do not continue driving your car ...
If it is *not* blinking, and as you noted, all else seems fine...then as advised, drive it to an AutoZone for a CEL check.
When you receive the code from them (they can seldom 'tell' you what is wrong...just give you the code(s) thrown)...then check the codes against this UTH sticky
Good Luck!
- Dave
Old Aug 23, 2010 | 05:35 PM
yeaitsahonda's Avatar
I lol'd.
Old Aug 23, 2010 | 05:42 PM
C Ory's Avatar
If you get out and about, and get close to Hampton, stop by my shop, and I'll scan it for you, and let you know whats wrong. Free of charge of course.
Old Aug 23, 2010 | 06:01 PM
Budman05's Avatar
You should own an ODB-II anyhow. They are about $100 plus or minus a bit. Mine has paid for itself many times over.
Old Aug 23, 2010 | 07:47 PM
FASTSIIK's Avatar
Done anything recently that could possibly be related?
Old Aug 24, 2010 | 02:28 AM
w1ngman's Avatar
I purchased a very decent reader w/ software that I've installed on a spare laptop. Got it on eBay for ~ $35 shipped as I recall .
