Help w/ VAFC 2
Old Jan 18, 2007 | 02:21 PM
CourageOO7's Avatar
Default Help w/ VAFC 2
Hey guys, I was hoping someone local might be able to take a look at my VAFC 2 installation. I am having this problem:
https://www.s2ki.com/forums/index.php?showt...0&#entry5108450
Basically, if I stay in VTEC too long (like at the track), my car won't let me get back into VTEC and gives me code: DTC P1259, Vtec system failure
If I turn the car off and back on I can Vtec again for short spurts but I can stay up there (like around a track).
If I reset my ecu the code will come back under the same conditions.
I would appreciate if someone more experienced with this kind of thing would take a look at my VAFC 2 installation/setup as I did not install it on the car (the previous owner did).
Can anyone help?
Thanks!
J
Old Jan 18, 2007 | 04:51 PM
papa5murf's Avatar
Your settings have to be off. I ran a Vafc II back in the days for about a year and had no issues at all. Grab the manual and start from the start.
Old Jan 18, 2007 | 06:43 PM
CourageOO7's Avatar
Dylan, so you think it's my settings and definitely not my physical wiring?
Old Jan 18, 2007 | 06:53 PM
CourageOO7's Avatar
Also, I don't have a manual and don't feel confident tuning my own car. Would anyone be willing to give me a run through on the VAFC 2 if the problem is my settings and not wiring?
Thanks,
J
Old Jan 18, 2007 | 07:08 PM
bighead's Avatar
[QUOTE=CourageOO7,Jan 18 2007, 10:53 PM] Also, I don't have a manual and don't feel confident tuning my own car.
Old Jan 18, 2007 | 07:21 PM
CourageOO7's Avatar
Cool Bill, thanks very much!
Old Jan 18, 2007 | 09:02 PM
Gernby's Avatar
Former Sponsor
I suspect that you either have a VAFC wiring problem, defective VAFC, defective VTEC solenoid, or oil pressure problem. If your VTEC works sometimes, but not all the time, it has nothing to do with settings.
Old Jan 19, 2007 | 03:34 AM
cap1's Avatar
Originally Posted by bighead2,Jan 18 2007, 11:08 PM
I can show you through it on Sunday, I'm running Dylan's old one so if we need to verify settings we can as well
http://www.apexi-usa.com/pdfInstallation/25.pdf <- that's the manual in psf format
Good job CO
Old Jan 19, 2007 | 04:18 AM
papa5murf's Avatar
You're not using the frog harness?... If you're not, you should pick one up, It eliminates all possible wiring issues.
The setup on the vafc is easy, you just need to put in the proper parameters and you can leave the tuning as is or set it all to zero and then take it in to get tuned.
rikhemi
Jan 14, 2008 02:28 PM
jdm j
San Diego S2000 Owners
Jul 28, 2007 01:01 PM
mustangkiller01
Aug 13, 2006 06:40 AM
s2kboy03
Apr 23, 2005 08:47 AM
