Roll bar with no diagonal
Old Jun 7, 2013 | 10:47 AM
ckim715's Avatar
Default Roll bar with no diagonal
Hey guys, a quick question: I'm looking to do occasional track days at VIR/Summit/NJMP, and was wondering: will a Hard Dog roll bar without a diagonal bar pass tech? I am trying to retain as much interior as possible. Thanks.
Old Jun 7, 2013 | 10:58 AM
TopGear's Avatar
I'm not sure on the tech question, but I have a single diagonal hard dog bar, and I don't think the diagonal affected the amount of interior bits I had to remove. I think the only change with the diagonal is that the passenger seat doesn't slide quite as far back as it used to.
I might be wrong though. I never made much of an effort to get all of my interior back in.
Old Jun 7, 2013 | 11:23 AM
TubeDriver's Avatar
Does it have rear supports? If so, you are probably fine. Technically, it should have a diagonal support but if it is a real hoop with rear supports, I would hop in the car without much hesitation. You could get one welded in for probably about $50.
Old Jun 7, 2013 | 11:28 AM
ckim715's Avatar
By rear supports I assume you mean 4 points of contact? Yes it would.
Old Jun 7, 2013 | 01:24 PM
postman's Avatar
^ this
if you are purchasing a new hard dog bar get a removable diagonal. this way you can take it out when not at the track.
regardless the diagonal is the least of your worries about the interior. the main hoop and rear supports are what take up most of the interior. if you have courage you can trim the interior around and make it look factory-ish. if you happen to be at summit point hyperfest weekend, hit me up and you can see how i reinstalled my interior.
Old Jun 10, 2013 | 04:04 AM
//steve\\'s Avatar
^Exactly what he said. The diagonal doesn't change too much about the rear interior. It's everything else that does.
LeManS2k
Jun 15, 2017 02:34 AM
jamesac83
Apr 10, 2015 11:18 AM
KnowledgeIsPower
Apr 13, 2013 03:16 PM
Currahee474
Feb 9, 2008 04:07 PM
johnhv
Jun 2, 2007 10:18 AM
