Test pipe
Old Oct 30, 2012 | 06:48 PM
Aarnett1993's Avatar
Default Test pipe
What is a good test pipe that doesn't throw any engine codes.
Old Oct 30, 2012 | 07:06 PM
koreanbro's Avatar
I think most of the test pipe throws codes..... just attach spark plug fouler to give the space between the pipe and o2 sensor, that should avoid the codes.
Old Oct 31, 2012 | 03:42 AM
Thanks I appreciate it
Old Oct 31, 2012 | 09:36 AM
loksfst's Avatar
I think the berk ones aren't supposed to throw codes....
Old Oct 31, 2012 | 10:57 AM
Baron2099's Avatar
I have a BERK TP installed on my car and it has an o2 Cel Fix that you plug into and it works fine had it installed for a little over 2 years now
Old Oct 31, 2012 | 12:08 PM
Okay ill look into that for sure and what size should I get like 70mm or 60mm or what?
Old Oct 31, 2012 | 01:18 PM
Baron2099's Avatar
Mine is a 70mm. I'm not sure but wouldn't you want to try and match up the diameter of the TP up to diameter of the Exhaust? DO you headers at all?
Old Oct 31, 2012 | 04:01 PM
I just have a stock header on mine
amusepanda
Apr 23, 2009 04:56 PM
Siver18
Nov 16, 2006 06:22 PM
Integra21
Aug 2, 2006 02:40 PM
ajaydm
Aug 21, 2005 12:34 AM
