used 2003 s2k price - good deal?
Old 02-14-2008, 07:08 PM
ebchu's Avatar
Default used 2003 s2k price - good deal?
I am looking at a 2003 s2000 with 78k miles for 14k. the owner said he is willing to go a lower, what price should I negotiate to?
Are there any things I should be looking out for on such a high mileage s2000?
He said he just replaced the clutch and has been doing all the oil changes and recommended maintenance.
Old 02-14-2008, 07:15 PM
FISH22's Avatar
I wouldnt call 78k 'HIGH' miles. That actually sounds like a really good deal, especially for an 03. If he's willing to go lower, I'd be careful. Make sure to check this car out very well.
Do the basics, drive it around, listen to any loud whining or growling from the rear diff and any wierd noises from the engine tranny. Watch for any grinds in the tranny. You can go further, with a compression test on the engine.
Old 02-15-2008, 03:49 AM
cap1's Avatar
Old 02-15-2008, 04:40 AM
tacocat's Avatar
Received 2,087 Likes on 1,314 Posts
Search the boards, there is a thread for the highest mileage S on here. I think it was somewhere in the 250k range. So 78k is not bad at all. Its a Honda after all. 200k should be no problem if you maintain the car and dont mod it too much.
Old 02-15-2008, 07:51 AM
dalink's Avatar
wow really? 250k???? That is intense
Old 02-15-2008, 08:26 AM
Olegator's Avatar
Yeah, make sure to check the car inside out even if you really like it, I didn't do it and ended up with the broken diff :/
Old 02-15-2008, 09:36 AM
ebchu's Avatar
how do i check the condition of the diff? and how long should it last before I have to replace it?
Old 02-15-2008, 10:36 AM
animeS2K's Avatar
You can't really tell how long a diff is going to last... if it's whining and grinding, it's done. It could be perfectly quiet up until the point of failure.
In terms of how long it SHOULD last? It depends on how much you abuse the car. If you never dump the clutch/shock the driveline/try to drift/track the car and aren't throwing extra horsepower through there (supercharger/turbo) then there's little reason for the diff to break. Abuse it enough and it will eventually give out, though - as will other parts.
Old 02-15-2008, 12:26 PM
ebchu's Avatar
thanks for all the help guys.
RXM9600
02-22-2014 06:08 AM
satten
10-08-2012 03:39 PM
Black_griffin6
08-15-2010 05:28 AM
TForan
06-05-2007 02:12 PM
kaytwoess
06-09-2006 03:34 AM
Quick Reply: used 2003 s2k price - good deal?
