Help with car not starting
Old Mar 26, 2011 | 03:31 PM
kbmass's Avatar
Default Help with car not starting
Hi all,
Today I had a great drive with my S2000, then decided to use some gunk engine cleaner on the family Mistubishi Montero Sport. Followed directions, and then my wife took it for a drive for about 10 miles. Now is is sitting in the driveway with no start, no lights, no nothing. obviously, some water got where it shouldn't have . Any suggestions on what to look for? No lights, no wipers, no click when you turn the key, no nothing. Just a dead car.
I am a very novice mechanic, but any suggestions I will try to act on tomorrow.
Thanks
Ken
Old Mar 26, 2011 | 03:43 PM
boltonblue's Avatar
well I'd start with disconnecting the battery and put a a voltmeter across the terminals. you should see ~12 volts+ a little.
sometimes a coincidence is just a coincidence, you're battery may have died.
is there a master fuse assembly somewhere? if so you may have popped one.
Old Mar 26, 2011 | 03:57 PM
sujo's Avatar
battery/alternator
Old Mar 29, 2011 | 02:19 PM
Chazmo's Avatar
Yeah, I'd start by pulling the battery, making sure it's clean, and then putting it on a charger... although no lights or anything sounds more like a fuse than a (suddenly) dead battery.
Maybe you shorted the battery with water?
Old Mar 29, 2011 | 06:41 PM
boltonblue's Avatar
Assuming things were working before you washed it, it is almost impossible to drain a battery with just water.
As current ran through it, the water would hydrolyze and evaporate off. There is an awful lot of current to discharge.
That's why I think a fuse or sensor.
Old Mar 30, 2011 | 04:55 AM
Chazmo's Avatar
You hardware engineers....
Old Mar 30, 2011 | 07:05 AM
FitzyS2k's Avatar
in the main fuse box in the engine bay you will find sqaure fuses. one is your main fuse. sounds like you may have blown it. i did this once when i put the wrong terminals on the battery.
hahapopcorn
Jul 20, 2011 08:30 PM
msafountain
May 19, 2010 12:21 AM
blueap2
Aug 4, 2008 08:22 PM
jimpom23
Jan 15, 2007 01:58 AM
jss2k
Jan 30, 2005 10:13 AM
