Need help already.
Old Aug 2, 2008 | 07:16 PM
PuFF's Avatar
Originally Posted by zzziippyyy,Aug 2 2008, 01:54 PM
They moved the map to the firewall? Are you running a stock intake manifold?
looks like he has the stock intake manifold
anyways, sorry i didn't post some help...was in NH car show with glenn and scott
feel free to give me a ring bro, or text
Old Aug 3, 2008 | 05:06 AM
ScottyBallistic's Avatar
One you guys are all confuse .... first rule is what works for one will not work for the other as everyone has differnt mods .
AEM = no diagnostics through the OBD2 anymore or check light .
Changing the exhaust can change the AFR , more so if the cat was removed .
AEM ECU is very picky about battery voltage and Grounds .
MAP being on the fire wall is not unusual on a boosted car as the factory map is only good for so much . They more than likely upgraded him to the AEM MAP sensor .
Did you run the car at all with the new exhaust ? if so you could have damaged the car if it was running lean . Just putting the exhaust on does no justify why it does not start alone ??
Mike the tuner for ESP is a friend on mine , he can always call if he has a question
Old Aug 3, 2008 | 05:17 PM
Imsello's Avatar
actuallly it does start. Its running very choppy when I step on the gas though thats Why I had it towed to my shop, say a prayer for me, I hope I did no damage to the motor if I was running to lean, also looked at my supercharger pulley and my belt was off one notch. Can that make a difference? I think thats why the pulley seemed kind of loud, well im going to put the 10lb pulley on and a new belt hopefully everything is all and well with a good tune.
Old Aug 3, 2008 | 05:51 PM
I would have them do a compression test first and go from there ..
Old Aug 4, 2008 | 12:42 AM
03silver2000's Avatar
and check your plugs
Jordan
honeywheel11
Sep 4, 2015 04:27 AM
s2sickk
Oct 4, 2011 10:06 PM
BLAKANEZ AP1
Mar 29, 2009 06:12 PM
FearlessFife
Jan 8, 2008 05:18 AM
