New York - Upstate New York S2000 Owners All areas North of I-84 (Port Jervis to Putnam Lake) in New York State
next eng mod...
Old 12-22-2012, 10:19 AM
RIDGERCR's Avatar
Default next eng mod...
So I've been researching on some engine upgrades, especially from reading the Honda & Acura Performance Handbook by Mike Ancas published in 2004. There isn't much support about the S2000 as it was a new Honda when this book was published. But I am curious as to replacing fuel injectors to a bigger size.
So the question is; Should I go to a slightly bigger size injector to accomodate the engine mods installed now?
What size do you fellas recommend if so? (Dave and Jsenclosures, your thoughts based on your experiences?)
I realize that a proper engine tune on the dyno will yield the best results as every car is differnt to some degree. But with a large injector size this should, in theory, provide the extra piece in the puzzle.
Thanks guys.
Old 12-22-2012, 11:42 AM
RIDGERCR's Avatar
If it helps, current mods I've done thus far include the header, hi-flo cat, exhaust, intake system, 3mm overbore throttle body, Hondata head gasket. I'm just looking for an N/A tune at some point, no cams as of yet and no VTEC controller installed either.
The ECU is the stock unit as well.
Old 12-22-2012, 11:49 AM
JayC07's Avatar
Why dont you get a FlashPro?
Old 12-22-2012, 04:00 PM
Headchef's Avatar
Jeremy, I don't know if I'm a fair comparison as I'm forced induction and quite modified. I'm running 750's. Might be a good idea to stop at Synapse when you get back and pick Morgans brain.
Old 12-22-2012, 04:28 PM
RIDGERCR's Avatar
Yeah, I thought I could talk it out with those guys at some time as they've had more than a few S2k's in their shop.
The ECU tuning will come after the injectors are swapped out. So no Flashpro for now.
Old 12-23-2012, 11:02 AM
shoes59's Avatar
I agree. Morgan installed 1000cc injectors on mine when going with my SC. If you remain NA i
would have your duty cycle checked. It may not be beneficial to go with bigger injectors.
Old 12-23-2012, 05:53 PM
jsenclosure's Avatar
If you're staying NA bigger injectors won't give you any advantage. Get an aem or other stand alone, and get a tune. The stock injectors are more than enough for NA
Unless your going FI injectors won't do you any good.
Old 12-23-2012, 08:33 PM
RIDGERCR's Avatar
Sounds good then, if anything the current injectors on there now could probably use a good cleaning as the car is now over 10 years old.
Sound advice guys, thanks for the input.
Mad Mart
09-05-2013 09:41 AM
02widowmaker
05-19-2011 10:08 PM
lobzdik
04-09-2010 10:39 AM
JimmyB
08-10-2007 09:35 PM
bloomac
01-21-2002 01:48 PM
Quick Reply: next eng mod...
