Attic ventilation
Old Jun 26, 2008 | 01:11 PM
mingster's Avatar
Default Attic ventilation
http://www.costco.com/Browse/Product.aspx?...&lang=en-US&s=1
does it really help?
Old Jun 26, 2008 | 01:16 PM
MikeyCB's Avatar
Your attic definitely needs to be vented, a mistake that many people make when putting in insulation themselves. Venting on the roof will reduce temperatures dramatically in your attic, and that heat release will reduce temps in your house.
Don't know about the need for a powered vent though.
Old Jun 26, 2008 | 02:51 PM
Sobe_Death's Avatar
Usually, an attic vent is thermostatically controlled. When it gets to a certain temp, the fan will kick on. Working in my parents attic recently and it was hot as hell up there. Looked around and discovered that their fan was never wired up when the house was built 15 years ago! Hooked it up and their upstairs temps dropped by 4 degrees.
Old Jun 26, 2008 | 04:33 PM
8_ball's Avatar
Depends. Is your attic finished (ie is there drywall or can you see the rafters)? If it is, chances are that there are vents in the roof soffits (the horizontal part that extends from the gutter back to the house) and a ridge vent at the peak of the roof. If this is the case, you should get plenty of circulatoin from just that. A powered fan like the one linked can make the attic more comfortable but the soffit & ridge vents will provide all the air circulation you need for the structure. If you can see the rafters, you may not have soffit and ridge vents. If this is the case, a powered ventilation fan will help give you circulation, assuming you can provide a fresh air draw (ie crack a outside window open). Easy quesiton, not so easy answers.
8kGoodENuff
Sep 22, 2009 07:26 PM
User 32625
Oct 7, 2006 04:42 PM
APLUS2K
Apr 27, 2005 08:05 AM
