Can A Plane Take Off On A Treadmill?
Old Feb 11, 2008 | 02:04 PM
  #201
S2020's Avatar
Corner!!!!!!!!!!!
Old Feb 11, 2008 | 02:07 PM
  #202
S2KANDRE's Avatar
Originally Posted by NFRs2000NYC,Feb 10 2008, 04:56 PM
The engines are moving air over the wings. When a propeller is spinning, it is pushing air over the wings, regardless of the planes motion.
Even if the engines are mounted over the wing, it still shouldn't be producing lift by causing wind to flow over the wings. The generated wind goes in and out of the engines.
If what you said held true, planes wouldn't need a take off strip. They would just take off like a helicopter.
Old Feb 11, 2008 | 02:34 PM
  #203
SheDrivesIt's Avatar
VTOL planes can do just that.
Old Feb 11, 2008 | 02:36 PM
  #204
MitsukillinS2K's Avatar
Originally Posted by YoZUpZ,Jan 25 2008, 12:46 PM
...Unless its a Harrier or Super Hornet
harrier yes hence its nickname JUMP JET.
Super Hornet not so much granted it takes very little distance to actually take off its still falls under the basic principal for flight. How do i know this? I work on Super Hornets.
Old Feb 11, 2008 | 06:20 PM
  #205
vtec9's Avatar
Originally Posted by S2020,Feb 11 2008, 06:04 PM
Corner!!!!!!!!!!!
send all the worthless crap there
Old Feb 11, 2008 | 07:06 PM
  #206
S2020's Avatar
yup
Old Feb 12, 2008 | 01:51 AM
  #207
Neutered Sputniks's Avatar
Because their engines tilt to work like Helicopter rotors.
Helicopter rotors basically pull the airframe up into the air (there is lift produced, but it's easier to explain it this way). Their directional movement is determined by the angle of the rotors relative to the ground (tilt forward, moves/pulled forward; tilt backwards, moves/pulled backwards; etc).
VTOL jets (Harriers) use the thrust of the engines to push the aircraft into the air, the thrust is then vectored to move them forward. Keep in mind, fighter jets use lift, but they act far more like a missile than an airplane. This is why airplanes can glide after power loss whereas fighter jets tend to plummet. The wings on a fighter jet serve more as control surfaces than for producing lift. This works because the speeds they travel at move enough air over the wings to produce enough lift for the aircraft to fly. Gliding speeds don't move enough air over the wings of a fighter to produce enough lift to keep the aircraft from stalling (the point at which the lift produced is less than the weight of the aircraft)
Old Feb 12, 2008 | 05:40 AM
  #208
Incubus's Avatar
Your previous posts have discredited your knowledge of aeronautics.
Old Feb 12, 2008 | 06:24 AM
  #209
duboseq's Avatar
What do you mean?
Old Feb 12, 2008 | 06:38 AM
  #210
Incubus's Avatar
Originally Posted by duboseq,Feb 12 2008, 03:24 PM
What do you mean?
He's been going on about how the treadmill will cancel the forward motion of the plane, even after eight pages of people explaining otherwise, Mythbusters' demonstration, and videos on Youtube.
It just seemed like he was trying to redeem himself; I don't know.
