Cisco routing ?????
Old Aug 22, 2003 | 11:11 AM
Drunken_Monk's Avatar
What is the gateway and DNS settings of the router? Are you sure that you have them set correctly? Can you ping via DNS name for the interface?
Old Aug 22, 2003 | 12:16 PM
nexus's Avatar
post a copy of your running config here. obviously remove the passwords before you post. if anyone is going to be able to help you, we'll need more real data. on the client machine do a route print and post that info also. any other pertinent data can only help.
Old Aug 22, 2003 | 12:28 PM
Fed's Avatar
Fed
Thanks for all your help guys, but I was able to figure it out. my internal addresses were private IPs and I needed to have them NATed to public ones in order to send anything out to the internet.
However maybe you can help me with this. I have 2 addresses NATed on my router, the internal router IP and the external IP on my firewall. Now, I need to setup a Citrix server so that I can connect to it from the internet.
I have already setup the Nat on the firewall, and setup the static route on the router. Is that the correct way of doing it?
Old Aug 22, 2003 | 12:34 PM
matrix's Avatar
Do you really want to pass this info over the internet in the clear? IE anyone can intercept/read it? I would recommend an IP VPN for this...
Old Aug 22, 2003 | 12:44 PM
Fed's Avatar
Fed
I actually do want this setup this way, becasue this server is used for remote access.
Old Aug 22, 2003 | 12:49 PM
matrix's Avatar
Are you encrypting the connections?
Old Aug 22, 2003 | 12:52 PM
Fed's Avatar
Fed
Yes I am.
Mr. Francesco
Jun 9, 2004 03:10 PM
tcd
Feb 19, 2004 10:29 PM
1Fast99Si
Jan 26, 2004 07:21 AM
