Linux help
Old Dec 31, 2001 | 01:27 PM
  #31
turbolane's Avatar
Originally posted by cthree
Ok, I think I remember what's going on here. Type netstat -nr. You probably have 2 routes to 0.0.0.0. You need to remove one of them. I think you've got two default routes.
Could be, but I'm not sure how to read the output. I do have two "destinations" of 0.0.0.0, one for each IP range (static and DHCP). How do I remove one, and which? (I'd assume the DHCP's).
PS: probably not reachable now, rebooting, etc.
Old Dec 31, 2001 | 01:29 PM
  #32
moonpie's Avatar
0.0.0.0 means default route. You can go, "route del default" and it will remove one of them..which one? who knows hehe..
tell me which interface is what?
example:
eth0 internal dhcp
eth1 external static
Old Dec 31, 2001 | 01:44 PM
  #33
turbolane's Avatar
[QUOTE]Originally posted by moonpie
[B]0.0.0.0 means default route.
Old Dec 31, 2001 | 01:51 PM
  #34
moonpie's Avatar
just logged in, so should be good to go then.
  #35
DSF_S2k's Avatar
Yep... can connect.
Dale
Old Dec 31, 2001 | 02:10 PM
  #36
turbolane's Avatar
Great, thanks for the help!
netatalk is still working as well, that's good. Have to check samba after I get a working windows machine again.
Old Dec 31, 2001 | 02:30 PM
  #37
moonpie's Avatar
Lane,
You're running a lot of extraneous services that could lead to the compromise of your system. I'd recommend shutting off all services unless you absolutely need them!
You're running:
Port State Service
13/tcp open daytime
21/tcp open ftp
23/tcp open telnet
37/tcp open time
79/tcp open finger
111/tcp open sunrpc
137/tcp filtered netbios-ns
138/tcp filtered netbios-dgm
139/tcp filtered netbios-ssn
445/tcp filtered microsoft-ds
514/tcp open shell
548/tcp open afpovertcp
1024/tcp open kdm
The only one you need is ftp right? You really should be using ssh for remote admin instead of telnet. You can shutdown and prevent the following services from starting up by issuing the following commands as root: (these are xinetd based services)
chkconfig daytime off
chkconfig time off
chkconfig finger off
chkconfig rsh off
You also have standalone daemons running that should be turned off. So you'll need to issue 2 commands per daemon - one to shut if off now, and the other to prevent it from starting at next boot time.
chkconfig portmap off
service portmap stop
chkconfig nfslock off
service nfslock off
If you want to disable telnet and use SSH instead, follow the above commands for an xinetd based service, then turn on sshd and start it up at next boot with the following commands:
chkconfig telnet off
service sshd start
chkconfig sshd on
Additionally, upgrade Wu-ftpd asap!
I can help with samba also if you need it. Also, you can read O'reilly's Samba book at my site listed below.
Old Dec 31, 2001 | 02:40 PM
  #38
DSF_S2k's Avatar
Yes Yes...
Get rid of those extra services, especially finger, rsh and time.... these are the first places to compromise a system, as well as wu-ftp..... update it.
Ah.... I love nmap
Dale
Old Dec 31, 2001 | 02:45 PM
  #39
moonpie's Avatar
I would ditch wu-ftpd completely and replace it with something more secure, such as pro-ftpd, or I'd even consider running OpenBSD's ftp server. There are soooo many remote r00t exploits for wu it's not even funny.
Old Dec 31, 2001 | 03:52 PM
  #40
turbolane's Avatar
I wouldn't mind running pro-ftpd, and have once before...but it took days to get it setup correctly. Is there an "easy" install method for it for RedHat 7.1 (I checked, I am running 7.1).
Thanks for the info on the other daemons, I'll turn them off asap. (I had finger running so I could have a .plan up, but never got around to it so might as well turn it off).
I used RH's "up2date" to update wu-ftpd, so short term that should be OK.
