Linux help
Old Mar 16, 2002 | 04:16 AM
  #51
moonpie's Avatar
lane: would you draw me a diagram of your current setup? I'm having a hard time picturing your setup.
Also, you can check to see if ip forwarding is enabled by running the following command:
cat /proc/sys/net/ipv4/ip_forward
if the return value is 1 you are setup to forward (route) packets. If not, you're OK.
Old Mar 16, 2002 | 10:32 AM
  #52
turbolane's Avatar
[QUOTE]Originally posted by moonpie
[B]lane:
Old Mar 16, 2002 | 01:06 PM
  #53
moonpie's Avatar
thanks for the diagram. Not to be a pain to suggest this, but why don't you go back to your old config (linux box with two nics) but have both nics configured statically?
This way you can maintain control over your routing table.
As to why samba isn't working anymore...have you tried to manually map a drive? You may also want to restart smb by going:
service smb restart
Old Mar 16, 2002 | 05:49 PM
  #54
turbolane's Avatar
[B]thanks for the diagram.
Old Mar 16, 2002 | 06:33 PM
  #55
moonpie's Avatar
Welp, pretty hard to troubleshoot remotely without a shell account, so I can't really think of what else to tell you about samba not working...could prolly figure it out in minutes with a user level shell account if you like.
Looking at your current diagram, I would also suggest that you stick a firewall in front of your DSL connection, to protect the servers, and another firewall between networks to protect your workstations. As I understand it, you have a firewall on your cable connection but not one on your DSL connection, and the two networks are connected, so a gaping hole exists there.
Good luck!
Old Mar 16, 2002 | 08:08 PM
  #56
turbolane's Avatar
[B]Welp, pretty hard to troubleshoot remotely without a shell account, so I can't really think of what else to tell you about samba not working...could prolly figure it out in minutes with a user level shell account if you like.
X Factor
Dec 11, 2004 03:46 PM
OverBooster
May 17, 2004 06:45 AM
VTEC_Junkie
Mar 11, 2004 07:48 AM
s2kdriver80
Apr 11, 2003 02:31 PM
S2K Fan
Apr 27, 2002 05:43 PM
