crazy offsets only...
I'm fitting a 9.5" +38 rear with only a roll and minor pull. Were going to either cut the rear inner lip off then pull or just roll it as flat as possible. Were going asia007 nasty pull style. 10" +18 is only 25mm more aggressive outer position. I'm at the least amount of camber I can have and I'm at -4 right now. I know people say it can't be done on oem camber joints but I've been to -7. With another -2 or -3 more camber with a 15mm pull, I know it could be done. You can see on the rpf1 thread how the 9.5"+38 with a 245/40 up front with -2 camber with ample room to clear the tire. The only concern I have is how will -7 camber wear on the diff. When I was at -6 it smelled to high holy hell until I backed the camber down to -4.
Originally Posted by berlinas2k2,Mar 2 2010, 04:10 PM
18x8 18x9 +38 All around. These were on a 225 Front and a 245 Rear tire. My old setup, I miss it!
with 5mm spacers rear
now
