Hey guys, check this out
I tried out my TARIS ECUExplorer logging software tonight. Pretty neat stuff. You can select from about 50 signals from the ECU, then log them by using the rear defrost button as the start/stop button.
Here are some preliminary results I got tonight:
Target boost for Cobb STage 2 is 17.5 PSI - so I'm good there. And any knock correction values above 0 means there is no knocking occuring - so I'm good there too. I'm slowing learning the software, but my next set of logs will allow me to also show A/F ratios and ECU learning rates. You can also see Intake AIr Temperatures of 25 degrees celcius. Peak temps (not shown in the log) peaked at 52 degrees during some stop and go driving Those top mount intercoolers are notorious for heat soak. The graph shows 2 back to back runs and logging Boost pressures - the car is pretty consistent in that sense.
i know Hapa, its freaking amazing!!
Its pretty cool if you're into modding the car, because then you can actually see what's happening and whether your car is reacting positively or negatively.
It would be also nice to log during a lapping session - as it shows vehicle speeds as well.
07-20-2013 08:25 AM
