3 port setup?
Old Oct 22, 2012 | 09:06 PM
Excalibur's Avatar
Default 3 port setup?
I'm looking at getting my 3port set up and then another tune. The place that I plan on tuning the car is around 350 miles away. I have to send the ecu to hondata to get it configured for the 3port boost control. My question is: Is there a way to get everything set up for the 3 port boost control and then drive the car cautiously to the tuner for the tune with the vacuum lines disconnected? What is the best route to go with this? Otherwise, I will have to take the car there, then send the ecu out and wait for it to return which will be a huge inconvenience for me as it's so far away. Thanks for any help.
Old Oct 23, 2012 | 07:15 AM
sohc_mshue's Avatar
You can hook the solenoid setup up prior to tuning and drive it.
Old Oct 23, 2012 | 09:48 AM
gettin it's Avatar
Ditto, thats what i did. Just drove normal, and out of boost.
s2knoob89's Avatar
This
It should stay at wastegate spring pressure until you start turning the duty cycle up on the solenoid.
Old Oct 23, 2012 | 07:42 PM
Excalibur's Avatar
Ok, so what are the steps?
Send the ecu to hondata
wire the solenoid
run the vac lines
then........
Old Oct 23, 2012 | 07:58 PM
skinsfn36's Avatar
Why not a 4 port?
I thought those were supposed to be the new thing, run a weaker (less boost psi) WG spring (for 1st gear), but can still crank the boost way up
Jaspah
Feb 23, 2017 11:22 PM
08s2000CRbackinblack
Aug 17, 2013 10:23 PM
6262
Jul 20, 2013 08:25 AM
Hondata
Apr 6, 2011 06:37 AM
s4000k racing
Nov 5, 2005 11:14 AM
